BC660K-GL Reserved eSIM
we are starting to design hardware based on LPWA BC660K-GL NB2. The webpage at LPWA BC660K-GL NB2 | Quectel mentions that it has a built-in eSIM reserved. Does it mean that we can use eSIM on these devices? I cannot see any documentation on the AT commands list related to eSIM.
Thanks in advance.
Yes, the eSIM position is reserved inside the BC660K module. If your terminal has a size limit, you can place the eSIM inside the module. This demand requires you to contact the sales to confirm the relevant order
Ok! Understood, so it is the ability to place an eSIM inside the module, but not an iSIM that can be provisioned on the module via AT commands.
iSIM is not supported for now
