The current file system example example_fs.c code in the V1.0 SDK does not work out of the box. This is due to the code trying to use the maintask_queue before it had the chance to be created.
Since we don’t know exactly when the MSG_ID_URC_INDICATION message will be sent by the driver we have to ensure that we have our queue setup before trying to use. The default code returned osStatus_t osErrorParameter (-4) indicating that the parameter passed to the osMessageQueuePut(maintask_queue, &msg, 0,0) on the line marked /* here */ was invalid.
The code below shows that the maintask_queue = osMessageQueueNew(8, sizeof(msg), NULL) MUST be done much earlier in time, even before registering the pscallback call back.
static s32 pscallback(ENUMurcID eventId, void *param, u32 paramLen)
CmiSimImsiStr *pCmiSimImsiInd = NULL;
ST_MSG msg;
switch (eventId)
case URC_ID_SIM_READY:
pCmiSimImsiInd = (CmiSimImsiStr *)param;
APP_DEBUG("SIM_READY:[%s]\r\n",pCmiSimImsiInd->contents);
msg.message = MSG_ID_URC_INDICATION;
msg.param1 = URC_SIM_CARD_STATE_IND;
osMessageQueuePut(maintask_queue, &msg, 0,0); /* here */
break;
// other code remove for brevity
default:
break;
return 0;
void proc_main_task(void)
s32 ret = -1;
ST_MSG msg;
u8 nw_state = 0;
Ql_SleepDisable();
Ql_RIL_Initialize();
Ql_UART_Open(UART_PORT0,115200,MainUartRecvCallback);
maintask_queue = osMessageQueueNew(8, sizeof(msg), NULL);
APP_DEBUG("<-- QuecOpen: File Example -->\r\n");
ret = Ql_PSCallback_Register(GROUP_ALL_MASK,pscallback);
osDelay(1000);
while (1)
APP_DEBUG("11 ");
if(osOK == osMessageQueueGet(maintask_queue,(void*)&msg, NULL, osWaitForever))
APP_DEBUG("12 ");
switch(msg.message)
case MSG_ID_URC_INDICATION:
//APP_DEBUG("<-- Received URC: type: %d, -->\r\n", msg.param1);
switch (msg.param1)
case URC_SIM_CARD_STATE_IND:
msg.message = MSG_ID_APP_START;
msg.param1 = STATE_GET_SPACE1;
APP_DEBUG("<-- Module has registered to network, status:%d -->\r\n",nw_state);
break;
default:
APP_DEBUG("<-- Other URC: type = %d\r\n", msg.param1);
break;
break;
default:
break;
