Is it possible to power off BC660K-GL using an AT command? With BC66 it was possible to use AT+QPOWD, but such a command is not supported by BC660K-GL. The documentation describes only HW way - power cycle the module.
Yes, the BC660K does not support AT command for power-off;you need to use hardware mode
