I’m taking my first steps with QuecOpen.
My goal is to make a NB-IoT version of one of our Sigfox sensor.
As a first try, I compiled and build example_gpio sample from the SDK and tried to flashed a custom board I made, equiped with a BC660K-GL module.
Note : my custom board seems to be fully functionnal with the original firmware. All the AT commands are responding correctly.
Flashing the module with the custom firmware is not a problem. But when I reset it, debug UART give me some strange outputs :
[2022-11-30_18:13:13:324]boot rom try normal boot start!
[2022-11-30_18:13:13:324] AUDPSProcedure 4.0
[2022-11-30_18:13:13:338]Fota base: 0x2d0000
[2022-11-30_18:13:13:338]adups_IsPartPackge
[2022-11-30_18:13:13:338]ÿÿÿÿÿ
[2022-11-30_18:13:13:338]adups_IsPartPackge: NO!
[2022-11-30_18:13:13:338]adups Packge: not found!
[2022-11-30_18:13:13:338]bootloader try normal boot system start!
[2022-11-30_18:13:13:338]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-11-30_18:13:13:338]test:VerifyImageHead skip
[2022-11-30_18:13:13:338]VerifyImageBody sha256 skip
[2022-11-30_18:13:13:387]boot rom try download from uart start!
[2022-11-30_18:13:13:387] download not success( 0x96)
[2022-11-30_18:13:29:386] boot rom try download from uart start!
[2022-11-30_18:13:29:386] download not success( 0x96)
[2022-11-30_18:13:45:392] boot rom try download from uart start!
[2022-11-30_18:13:45:392] download not success( 0x96)
[2022-11-30_18:14:01:399] boot rom try download from uart start!
[2022-11-30_18:14:01:399] download not success( 0x96)
[2022-11-30_18:14:17:407] boot rom try download from uart start!
Of course, the led connected on GPIO1 does not blink.
I cannot find any information about these messages.
Is there any thing I made wrong ?
I don’t think the BOOT pull is concerned since the module works correctly when flashed with the original BC660K-GL firmware.
The log in my first message was incorrect. Bellow is the output I receive on debug UART when I reset the module after flashing it with my own firmware :
[2022-12-01_13:06:22:933]boot rom try normal boot start!
[2022-12-01_13:06:22:933] AUDPSProcedure 4.0
[2022-12-01_13:06:22:957]Fota base: 0x2d0000
[2022-12-01_13:06:22:957]adups_IsPartPackge
[2022-12-01_13:06:22:957]ÿÿÿÿÿ
[2022-12-01_13:06:22:957]adups_IsPartPackge: NO!
[2022-12-01_13:06:22:957]adups Packge: not found!
[2022-12-01_13:06:22:957]bootloader try normal boot system start!
[2022-12-01_13:06:22:957]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-01_13:06:22:957]test:VerifyImageHead skip
[2022-12-01_13:06:22:957]VerifyImageBody sha256 skip
Thank you for this information.
Indeed, my compiled firmware and the original BC660 firmware outputs are the same.
Everything works fine when the module is flashed with BC660 firmware. I can use it throught the main uart.
But when the module is flashed with my firmware (I used example from BC660 QuecOpen Quick Start Guide), I don’t see anything on the main uart because the module is stuck in a boot loop :
[2022-12-05_11:15:55:031]boot rom try normal boot start!
[2022-12-05_11:15:55:031] AUDPSProcedure 4.0
[2022-12-05_11:15:55:053]Fota base: 0x2d0000
[2022-12-05_11:15:55:053]adups_IsPartPackge
[2022-12-05_11:15:55:053]ÿÿÿÿÿ
[2022-12-05_11:15:55:053]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:053]adups Packge: not found!
[2022-12-05_11:15:55:053]bootloader try normal boot system start!
[2022-12-05_11:15:55:053]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:053]test:VerifyImageHead skip
[2022-12-05_11:15:55:053]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:092]boot rom try normal boot start!
[2022-12-05_11:15:55:092] AUDPSProcedure 4.0
[2022-12-05_11:15:55:110]Fota base: 0x2d0000
[2022-12-05_11:15:55:110]adups_IsPartPackge
[2022-12-05_11:15:55:110]ÿÿÿÿÿ
[2022-12-05_11:15:55:110]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:110]adups Packge: not found!
[2022-12-05_11:15:55:110]bootloader try normal boot system start!
[2022-12-05_11:15:55:110]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:110]test:VerifyImageHead skip
[2022-12-05_11:15:55:110]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:138]boot rom try normal boot start!
[2022-12-05_11:15:55:138] AUDPSProcedure 4.0
[2022-12-05_11:15:55:165]Fota base: 0x2d0000
[2022-12-05_11:15:55:165]adups_IsPartPackge
[2022-12-05_11:15:55:165]ÿÿÿÿÿ
[2022-12-05_11:15:55:165]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:165]adups Packge: not found!
[2022-12-05_11:15:55:165]bootloader try normal boot system start!
[2022-12-05_11:15:55:165]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:165]test:VerifyImageHead skip
[2022-12-05_11:15:55:165]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:200]boot rom try normal boot start!
[2022-12-05_11:15:55:200] AUDPSProcedure 4.0
[2022-12-05_11:15:55:222]Fota base: 0x2d0000
[2022-12-05_11:15:55:222]adups_IsPartPackge
[2022-12-05_11:15:55:222]ÿÿÿÿÿ
[2022-12-05_11:15:55:222]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:222]adups Packge: not found!
[2022-12-05_11:15:55:222]bootloader try normal boot system start!
[2022-12-05_11:15:55:222]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:222]test:VerifyImageHead skip
[2022-12-05_11:15:55:222]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:260]boot rom try normal boot start!
[2022-12-05_11:15:55:260] AUDPSProcedure 4.0
[2022-12-05_11:15:55:280]Fota base: 0x2d0000
[2022-12-05_11:15:55:280]adups_IsPartPackge
[2022-12-05_11:15:55:280]ÿÿÿÿÿ
[2022-12-05_11:15:55:280]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:280]adups Packge: not found!
[2022-12-05_11:15:55:280]bootloader try normal boot system start!
[2022-12-05_11:15:55:280]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:280]test:VerifyImageHead skip
[2022-12-05_11:15:55:280]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:321]boot rom try normal boot start!
[2022-12-05_11:15:55:321] AUDPSProcedure 4.0
[2022-12-05_11:15:55:336]Fota base: 0x2d0000
[2022-12-05_11:15:55:336]adups_IsPartPackge
[2022-12-05_11:15:55:336]ÿÿÿÿÿ
[2022-12-05_11:15:55:336]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:336]adups Packge: not found!
[2022-12-05_11:15:55:336]bootloader try normal boot system start!
[2022-12-05_11:15:55:336]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:336]test:VerifyImageHead skip
[2022-12-05_11:15:55:336]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:366]boot rom try normal boot start!
[2022-12-05_11:15:55:366] AUDPSProcedure 4.0
[2022-12-05_11:15:55:392]Fota base: 0x2d0000
[2022-12-05_11:15:55:392]adups_IsPartPackge
[2022-12-05_11:15:55:392]ÿÿÿÿÿ
[2022-12-05_11:15:55:392]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:392]adups Packge: not found!
[2022-12-05_11:15:55:392]bootloader try normal boot system start!
[2022-12-05_11:15:55:392]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:392]test:VerifyImageHead skip
[2022-12-05_11:15:55:392]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:444]boot rom try normal boot start!
[2022-12-05_11:15:55:444] AUDPSProcedure 4.0
[2022-12-05_11:15:55:449]Fota base: 0x2d0000
[2022-12-05_11:15:55:449]adups_IsPartPackge
[2022-12-05_11:15:55:449]ÿÿÿÿÿ
[2022-12-05_11:15:55:449]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:449]adups Packge: not found!
[2022-12-05_11:15:55:449]bootloader try normal boot system start!
[2022-12-05_11:15:55:449]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:449]test:VerifyImageHead skip
[2022-12-05_11:15:55:449]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:490]boot rom try normal boot start!
[2022-12-05_11:15:55:490] AUDPSProcedure 4.0
[2022-12-05_11:15:55:506]Fota base: 0x2d0000
[2022-12-05_11:15:55:506]adups_IsPartPackge
[2022-12-05_11:15:55:506]ÿÿÿÿÿ
[2022-12-05_11:15:55:506]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:506]adups Packge: not found!
[2022-12-05_11:15:55:506]bootloader try normal boot system start!
[2022-12-05_11:15:55:506]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:506]test:VerifyImageHead skip
[2022-12-05_11:15:55:506]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:553]boot rom try normal boot start!
[2022-12-05_11:15:55:553] AUDPSProcedure 4.0
[2022-12-05_11:15:55:563]Fota base: 0x2d0000
[2022-12-05_11:15:55:563]adups_IsPartPackge
[2022-12-05_11:15:55:563]ÿÿÿÿÿ
[2022-12-05_11:15:55:563]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:563]adups Packge: not found!
[2022-12-05_11:15:55:563]bootloader try normal boot system start!
[2022-12-05_11:15:55:563]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:563]test:VerifyImageHead skip
[2022-12-05_11:15:55:563]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:598]boot rom try normal boot start!
[2022-12-05_11:15:55:598] AUDPSProcedure 4.0
[2022-12-05_11:15:55:619]Fota base: 0x2d0000
[2022-12-05_11:15:55:619]adups_IsPartPackge
[2022-12-05_11:15:55:619]ÿÿÿÿÿ
[2022-12-05_11:15:55:619]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:619]adups Packge: not found!
[2022-12-05_11:15:55:619]bootloader try normal boot system start!
[2022-12-05_11:15:55:619]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:619]test:VerifyImageHead skip
[2022-12-05_11:15:55:619]VerifyImageBody sha256 skip
[2022-12-05_11:15:55:659]boot rom try normal boot start!
[2022-12-05_11:15:55:659] AUDPSProcedure 4.0
[2022-12-05_11:15:55:679]Fota base: 0x2d0000
[2022-12-05_11:15:55:679]adups_IsPartPackge
[2022-12-05_11:15:55:679]ÿÿÿÿÿ
[2022-12-05_11:15:55:679]adups_IsPartPackge: NO!
[2022-12-05_11:15:55:679]adups Packge: not found!
[2022-12-05_11:15:55:679]bootloader try normal boot system start!
[2022-12-05_11:15:55:679]LoadVerifyImageHead read(len=272), Time(ms)->0.
[2022-12-05_11:15:55:679]test:VerifyImageHead skip
[2022-12-05_11:15:55:679]VerifyImageBody sha2
It’s the reason why I doubt about the correct firmware target or something about the build.
C:\QuecOpen\PLAT>gccmake.bat clean
build.bat version 20180330
GCCLIB_PATH: "C:/gcc"
OPTION: clean
(cd project/qcx212_0h00/quectel_project/quec_open && make -f Makefile clean)
make[1]: Entering directory '/cygdrive/c/QuecOpen/PLAT/project/qcx212_0h00/quectel_project/quec_open'
make[1]: Leaving directory '/cygdrive/c/QuecOpen/PLAT/project/qcx212_0h00/quectel_project/quec_open'
clean finished.
C:\QuecOpen\PLAT>gccmake.bat all
Start time: 02/12/2022 19:08:42.48
#################### STEP1: configuration #############################
configuration is successful
#################### STEP2: make quectel_ocpu_app #####################
(cd project/qcx212_0h00/quectel_project/quec_open && make V= -f Makefile all)
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/customer/main.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/customer/config/ql_task_def.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_util.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_urc.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_dfota.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_network.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_ntp.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_system.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/ril/src/ril_mqtt.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_lwip_tcpclient.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_ps.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_multitask.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_gpio.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_spi.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_adc.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_fs.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_dfota_http.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_lwip_udpclient.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_time.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_pwm.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_float_math.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_timer.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_mqtt.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_i2c.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_rtc.c
CC ../../../../../PLAT/project/qcx212_0h00/quectel_project/quec_open/example/example_eint.c
CC ../../../../../PLAT/os/freertos/src/timers.c
CC ../../../../../PLAT/os/freertos/src/tasks.c
CC ../../../../../PLAT/os/freertos/src/event_groups.c
CC ../../../../../PLAT/os/freertos/src/list.c
CC ../../../../../PLAT/os/freertos/src/queue.c
CC ../../../../../PLAT/os/freertos/src/heap_4.c
CC ../../../../../PLAT/os/freertos/CMSIS/src/os_systick.c
CC ../../../../../PLAT/os/freertos/CMSIS/src/os_callback_hook.c
CC ../../../../../PLAT/os/freertos/CMSIS/src/mm_debug.c
CC ../../../../../PLAT/os/freertos/CMSIS/src/cmsis_os2.c
CC ../../../../../PLAT/os/freertos/portable/gcc/port.c
LINK ../../../../../PLAT/gccout/APPNB5MDM32A01.elf
Memory region Used Size Region Size %age Used
LOAD_IRAM_MCUVECTOR: 100 B 100 B 100.00%
LOAD_IRAM_MCU: 4116 B 5020 B 81.99%
UNLOAD_DRAM_USRNV: 1 KB 1 KB 100.00%
LOAD_DRAM_MCU: 48 B 4 KB 1.17%
UNLOAD_DRAM_PSPHYRET: 6 KB 6 KB 100.00%
LOAD_IRAM: 35796 B 36 KB 97.10%
LOAD_DRAM_SHARED: 121888 B 152 KB 78.31%
LOAD_DRAM_BSP: 3884 B 8 KB 47.41%
UNLOAD_DRAM_FLASHMEM: 7 KB 7 KB 100.00%
UNLOAD_DRAM_SLPMEM: 224 B 992 B 22.58%
FLASH_APP: 2385296 B 2560 KB 90.99%
OBJCOPY ../../../../../PLAT/gccout/APPNB5MDM32A01.bin
text data bss dec hex filename
2378091 7196 133184 2518471 266dc7 ../../../../../PLAT/gccout/APPNB5MDM32A01.elf
mv ../../../../../PLAT/gccout/*.elf ../../../../../PLAT/gccout/APPNB5MDM32A01/dbg
mv ../../../../../PLAT/gccout/*.map ../../../../../PLAT/gccout/APPNB5MDM32A01/dbg
mv ../../../../../PLAT/gccout/*.symbols ../../../../../PLAT/gccout/APPNB5MDM32A01/dbg
mv ../../../../../PLAT/gccout/*.txt ../../../../../PLAT/gccout/APPNB5MDM32A01/dbg
cp ../../../../../PLAT/gccout/*.bin ../../../../../PLAT/gccout/APPNB5MDM32A01
cp ../../../../../PLAT/tools/flash_download.ini ../../../../../PLAT/gccout/APPNB5MDM32A01
cp ../../../../../PLAT/tools/MergeRfTable.bin ../../../../../PLAT/gccout/APPNB5MDM32A01
cp ../../../../../PLAT/tools/Bootloader.bin ../../../../../PLAT/gccout/APPNB5MDM32A01/Bootloader_APPNB5MDM32A01.bin
cp ../../../../../PLAT/tools/comdb.txt ../../../../../PLAT/gccout/APPNB5MDM32A01
sed -i "s|bootloader.bin|Bootloader_APPNB5MDM32A01.bin|g" ../../../../../PLAT/gccout/APPNB5MDM32A01/flash_download.ini
sed -i "s|app.bin|APPNB5MDM32A01.bin|g" ../../../../../PLAT/gccout/APPNB5MDM32A01/flash_download.ini
mv ../../../../../PLAT/gccout/*.bin ../../../../../PLAT/gccout/APPNB5MDM32A01
---------- .\GCCOUT\OUTBUILDLOG.LOG
warning_num= 0, error_num= 0
End time: 02/12/2022 19:09:13.19
Built took 0 hours 0 minutes 31 seconds
- GCC Compiling Finished Sucessfully.
- The target image is in the 'gccout\APPNB5MDM32A01' directory.
C:\QuecOpen\PLAT>
I answered my own question. The toolchain I used was wrong. Now I use GNU Arm Embedded Toolchain v10.3-2021.10 from Downloads | GNU Arm Embedded Toolchain Downloads – Arm Developer
Firmware is now built correctly and does not put my BC660 module in boot loop anymore.
Note for Quectel team : please update your Quick Start Guide (§4.1 Compiling Environment).
Last question : all my QuecOpen documentation is pretty old and marked as “preliminary”. Where can I download updates or last version of QuecOpen for BC660 ? Thanks
