BC660K_GL does not enter to deepsleep mode inmediatly after entering in PSM mode
Hi, I have been working on an application with the BC660K_GL module, the idea is to optimize the power usage, so for that I have the following configuration:
Send UDP message with RAI flag = 1, slplocktimes = 0, eDRX desactivated, TAU = “01000011” and active timer = “00000000”.
with this configuration, after sending the message, the module goes into deep sleep mode almost immediately but in one of the modules this does not happen.
Looking at the image above, you can see in two of them (green rectangle) that the module enters deepsleep at the same time they enter PSM, but the third one was almost 7 seconds in idle mode before entering deepsleep mode. I attach also the logs
(left side: expected result, right side: module with the problem)
What could be causing the problem?
Please provide your log attachment
Hi Herbert,
We have experienced the same issue. Could you please provide us some advice?
Best regards
Please provide your debug log
I’m experiencing that the BC660 goes to deep sleep 10 seconds after sending AT+QSCLK=1. What was the outcome of the issue above?
Quectel_Mechanism and Application Reference for PSM and Sleep Mode of NB-IoT Module.pdf (693.1 KB)
