BC660K-GL Current peak document inconsistency
We have found out an inconsistency on the current peak value between 2 documents:
quectel_bc660k-glbc66bc66-na_compatible_design_v1.1.pdf > Page 9 saysVBAT: Max. 0.8 A
quectel_bc660k-gl_hardware_design_v1.4.pdf > Page 24 says 0.5A
Power design for a module is critical to its performance. It is recommended to use a low quiescent current LDO with an output capacity of 0.5 A to regulate the power supply for BC660K-GL.
Which document is correct ?
