at+creg? It is usually used to query the status of GSM network. Currently, your device is registered in NBIOT network. It is recommended that you use AT+CEREG?
pls run
AT+QIDNSCFG?
AT+QIDNSGIP=1,“io.adafruit.com”
[2023-05-29_16:45:13:656]AT+QIDNSCFG=0,“8.8.8.8”,“8.8.4.4”
[2023-05-29_16:45:13:656]OK
[2023-05-29_16:45:20:642]AT+QIDNSCFG=0
[2023-05-29_16:45:20:642]+QIDNSCFG: 0,“8.8.8.8”,“8.8.4.4”,“”,“”
[2023-05-29_16:45:20:642]OK
[2023-05-29_16:45:27:762]AT+QIDNSGIP=0,“test.mosquitto.org”
[2023-05-29_16:45:27:762]OK
[2023-05-29_16:46:02:911]
[2023-05-29_16:46:02:911]+QIDNSGIP: 565
the problem continues
run AT+QPING=0,8.8.8.8
[2023-05-30_15:00:50:641]AT+QGMR
[2023-05-30_15:00:50:641]Quectel_Ltd
[2023-05-30_15:00:50:641]Quectel_BC660K-GL
[2023-05-30_15:00:50:641]Revision: BC660KGLAAR01A05_01.200.01.200
[2023-05-30_15:00:50:641]OK
[2023-05-30_15:00:51:578]AT+CPIN?
[2023-05-30_15:00:51:578]+CPIN: READY
[2023-05-30_15:00:51:578]OK
[2023-05-30_15:00:53:270]AT+CEREG?
[2023-05-30_15:00:53:270]+CEREG: 1,1
[2023-05-30_15:00:53:270]OK
[2023-05-30_15:00:54:581]AT+CGATT?
[2023-05-30_15:00:54:581]+CGATT: 1
[2023-05-30_15:00:54:581]OK
[2023-05-30_15:00:56:584]AT+CGPADDR
[2023-05-30_15:00:56:584]+CGPADDR: 0,“10.217.176.198”
[2023-05-30_15:00:56:584]+CGPADDR: 1
[2023-05-30_15:00:56:584]+CGPADDR: 2
[2023-05-30_15:00:56:584]OK
[2023-05-30_15:01:05:378]AT+CPSMS=0
[2023-05-30_15:01:05:378]OK
[2023-05-30_15:01:06:311]AT+QSCLK=0
[2023-05-30_15:01:06:311]OK
[2023-05-30_15:01:07:426]AT+CEDRXS=0
[2023-05-30_15:01:07:426]OK
[2023-05-30_15:01:09:823]AT+COPS?
[2023-05-30_15:01:09:823]+COPS: 0,2,“28602”,9
[2023-05-30_15:01:09:823]OK
[2023-05-30_15:01:13:315]AT+QPING=0,8.8.8.8
[2023-05-30_15:01:13:315]OK
[2023-05-30_15:01:17:442]
[2023-05-30_15:01:17:442]+QPING: 569
[2023-05-30_15:01:21:446]
[2023-05-30_15:01:21:446]+QPING: 569
[2023-05-30_15:01:25:453]
[2023-05-30_15:01:25:453]+QPING: 569
[2023-05-30_15:01:29:461]
[2023-05-30_15:01:29:461]+QPING: 569
[2023-05-30_15:01:29:461]+QPING: 0,4,0,4,0,0,0
I think your SIM card is limited and cannot interact with data
thanks for helping, we solve with vodafone.
BEST
Hello , how did you solve ? I am facing the same problem with my network provider
This incident might be caused by the operator restricting the IP access of your device, or by the requirement for the device to access a specific IP for certain services.
How did you solve please i have a similar problem
