BC660K failed to open network connection
I am using BC660K-GL to send message using MQTT protocol. By using same NBIOT simcard on the BG96 module, it is connected and send data. the same simcard is not working with BC660K.
The log is as follow:
AT
AT
AT+QSCLK=0
AT+QSCLK=0
AT+CGMI;+CGMM;+CGMR;+CGSN;+CESQ
Quectel_Ltd
Quectel_BC660K-GL
Revision: QCX212
Quectel_BC660K-GL
Revision: BC660KGLAAR01A04
MPQ22EJ0B0246560P
+CESQ: 99,99,255,255,30,61
AT+CESQ;+CEREG?;+CGPADDR?
+CEREG: 0,1
+CGPADDR: 0,“90.50.200.60”
AT+CPIN?;+CSQ;+CEREG?;+COPS?
+CPIN: READY
+CSQ: 19,0
+CEREG: 0,1
+COPS: 0,2,“42422”,9
AT+QMTCFG=“version”,1,1
AT+QMTCFG=“timeout”,1,10,3,1
AT+QMTCFG=“session”,1,1
AT+QMTCFG=“keepalive”,1,0
AT+QMTCFG=“ssl”,1,0
AT+QMTCFG=“ssl”,1,0
AT+QMTOPEN=1,“mqtt-dashboard.com”,1883
+QMTOPEN: 1,-1
Please execute first
AT+QIDNSGIP=0,“mqtt-dashboard.com
Thank you,
but it returns 565.
+QIDNSGIP: 565
you try
AT+QIDNSCFG=0,8.8.8.8,8.8.4.4
or
AT+QMTOPEN=1," 3.77.175.147",1883
Great,
It works fine.
Thanks a lot
:smile:Glad to solve your problem
