Hello, I am trying to connect BC660K devboard to R&S CMW290 tester.
Modem version is BC660KGLAAR01A05_01.002.01.002
The modem scans for a bit and returns back to idle, the tester also shows nothing in the log. I am using the default CMW290 NB-IoT signaling app settings as I can not find any notes on what settings to use. What should I change in the CMW290 configuration for the modem to connect?
Thanks!
Could you please tell me which function do you want to test?
