Hi all,
I just received BC66-TE-B development board. The problem is I can not register to the operator.
After connecting to the computer, I reset the device with RESET button and after initial message from MODEM:
F1: 0000 0000
V0: 0000 0000 [0001]
00: 0006 000C
01: 0000 0000
U0: 0000 0001 [0000]
T0: 0000 00B4
Leaving the BROM
I follow these steps:
Turn off Power Saving Mode
AT+QSCLK=0
> OK
Turn off Echo Mode
AT0
> OK
Is PIN Code Required?
AT+CPIN?
> +CPIN: SIM PIN
Enter Pin
AT+CPIN="1234"
> OK
Stop Connecting
AT+CGATT=0
> OK
Get List of Available Operators
AT+COPS=?
> +COPS: (1,"23002","23002","23002",9),(1,"23003","23003","23003",9),(1,"23001","23001","23001",9),,(0-4),(0-2)
Select My Operator
AT+CFUN=0
> OK
AT+COPS=1,2,"23002"
> OK
AT+CGDCONT=1,"IP","internet"
> OK
AT+QCGDEFCONT="IP","internet"
> OK
AT+CFUN=1
> OK
> +CPIN: SIM PIN
AT+CPIN="1234"
> OK
Restart Modem
AT+QRST=1
> OK
Disable Power Saving Mode
AT+QSCLK=0
> OK
Disable Echo
ATE0
> OK
Enable Event Reporting
AT+QNBIOTEVENT=1,1
> OK
Check Signal Strength
AT+CSQ
> +CSQ: 99,99
That is weird, but maybe because we are not connected yet?
AT+CEREG=5
> OK
Connect
AT+CGATT?
> +CGATT: 0
Still off, turn it on… For some reason, turning it on with:
AT+CGATT=1
> ERROR
did not work. So I had to AT+CFUN=0 and AT+CFUN=1 again to start connecting.
Then this appeared:
+CEREG: 2,,,,,0,0
+CEREG: 3,,,,,0,15
+CEREG: 0,,,,,0,0
+CEREG: 2,,,,,0,0
+CEREG: 0,,,,,0,0
+CEREG: 2,,,,,0,0
+CEREG: 0,,,,,0,0
+CEREG: 2,,,,,0,0
Checking registration status returns:
AT+CGATT?
> +CGATT: 0
So we are still not connected. What is the status?
AT+CEREG?
> +CEREG: 5,0,,,,,0,0
Sometimes, this ends with +CEREG: 5,0, sometimes +CEREG:5,3…
Extended signal info still returns that there is no signal.
AT+CESQ
> +CESQ: 0,0,255,255,0,0
I don’t know, what I am doing wrong. Maybe I just set something wrong during my previous attempts and connection is failing because of that.
Or maybe my steps are not in right order, but I tried to follow application design workflow, as described in: Application Manual
Is there a chance, that my SIM card does not support this type of connection? To be honest, I still don’t know if I am using LTE or NB-IOT. Only thing which may be selecting between these two is AT+QBAND command, which is set to:
AT+QBAND?
> +QBAND: 20
Which should be supported: O2 Czech Republic
Because support from the operator is non-existing, I don’t know wheter is my fault, or something connected to SIM card setup on operator’s side.
Thank you in advance for any tips.
