Hi @ dopoljak
I didn’t investigate more into the issue. In order to access the GPIO without level converter you would probably need to solder a cable to the modem directly
Please, let me know if make any progress
enjoy…
(no level-convertor, bypass Olimex pin)
To what pin did you connect the sensor VCC? And what value is the resistor?
there is 18 free pins, select one…
R = approximately 1 mA for VCC ( I use 3.6k )
@WizIO did you manage to connect ultrasonic sensor directly to olimex pin (no need to bypass level convertor ?)
yep … I use SPI as “counter”
MOSI create the sensor triger
MISO read “bits” … the number of bits are derivatives of the SPI frequency
@WizIO gr8 :). is same posible with DHT & DS1820 sensor?
Ultrasonic HCSR04 over SPI
Hi, We had a good debugging session today and we were able to solve the Olimex - Dallas sensor noise issue. The issue was in the data line and high frequency noise was blocking the data connection mostly. We found out that there was fan out issue which generated the noise. So, by adding 220 ohm resistor series in both TxD and RxD line solved it. Now we can have 100% good temperature readings by using the posted code above in this thread. Great!
@JarkkoM That sounds great, could you share the wiring schematics of the final working setup with Dallas sensor?
