I have an issue when i try to send data to an Ip adresse by openingn a socket like this:
print(“AT+QIOPEN=1,0,“UDP”,“xx.xxx.xx.xx”,2204\r”);
Its workign but when i send to the domain name it’s not
print(“AT+QIOPEN=1,0,“UDP”,“telegraf.hello.io”,2204\r”);
Its not working
Hi Zineddine
AT+QIOPEN does not support domain name connections and only supports IP addresses.
You can use AT+QIDNSGIP to resolve the domain name into an IP address, and then execute AT+QIOPEN.
Could you please show me an example caus i dont understand?
the quiopen in the documention say that we can use a domain name
doc:
+QIOPEN: (1-3),(0-4),“TCP/UDP”,“<IP_address>/”,<remote_port>,<local_port>,(0-1)[,(0-1)]
Hi i got an error when i try to configure the dns.
print(“AT+QIDNSCFG=1,“12.224.255.252,212”.“224.255.254”\r”);
should be ok i suppose ?
i have also found something with my telecom provider.
They provide a dns when we configure the APN but this one is not used in my module the one that is used is this one: http://dns2.ctcdma.com/
Hi Zineddine
AT+QIDNSCFG=1,12.224.255.252,212.224.255.254
NOTES:
1、If the network supports IPv4, then only IPv4 DNS addresses can be set.
2、The DNS server address should be configured after IP address URC (e.g. +IP: 10.18.237.42,
indicating successfully registered to network) is reported.
3、The configuration is not saved to NVRAM, so re-configuration is required after next reboot and deep
sleep wake-up.
They provide a dns when we configure the APN but this one is not used in my module the one that is used is this one: [http://dns2.ctcdma.com/ ]
【Abner】I am sorry, I did not understand the question clearly. Could you share more detail about this issue? Thank you.
Hi Zineddine
software version error?ATI command Query software version.
confirm the DNS server address should be configured after IP address indicating successfully registered to network is reported.
