Hi @herbert.pan-Q , thanks for your advice.
The BC66 now successfully obtains an IP address URC, which is great! I used the AT+QCGDEFCONT=\"IP\",\"lpwa.vodafone.iot\" command to set the APN right.
However there are still some hurdles:
- Opening a UDP socket and sending data is now also possible, but as you can see below it takes many many failed attempts to open a socket before it succesfully opens. It also takes one failed attempt before I can succesfully send data. Furthermore, this pattern repeats itself every time I try to open a socket and send something: Many failed attempts before being succesful.
- After a while the BC66 stops being responsive to a PSM_EINT wakeup signal from the MCU (all the way at the bottom of the log). It seems it is locked in some kind of dead/sleep state which it can’t get out of… This is accompanied by the NETLIGHT going solid HIGH, which is most unusual (in the commands manual it doesn’t say anything about the netlight going solid HIGH).
Any suggestions as to what could be happening here would be most appreciated!
11:56:11.453 -> AT+IPR=9600
11:56:11.453 ->
11:56:11.453 -> ATE0
11:56:11.502 ->
11:56:12.488 -> AT+QSCLK=0
11:56:12.534 ->
11:56:13.525 -> AT+CMEE=1
11:56:13.573 ->
11:56:14.563 -> ATI
11:56:14.611 ->
Quectel_Ltd
Quectel_BC66
Revision: BC66NBR01A11
11:56:16.545 -> CEREG event: +CEREG: 5,"2CF1","018D4567",9,0,0,"00000000","01011111"
11:56:16.875 -> **IP event!: +IP: 100.93.192.183
11:56:18.717 -> Connected!
11:56:18.717 -> AT+QSCLK=1
11:56:18.764 ->
11:56:19.755 -> AT+QRELLOCK
11:56:19.802 ->
11:56:20.794 -> # Wait for BC66 to go to sleep --
11:56:31.018 -> Deep sleep event!
11:56:33.559 -> # Wait for BC66 wake up --
11:56:33.559 -> Send interrupt to BC66 PSM_EINT pin
11:56:33.985 -> CEREG event: +CEREG: 5,"2CF1","018D4567",9,0,0,"00000000","01011111"
11:56:34.032 -> Wake up event!
11:56:39.772 -> Connected!
11:56:39.772 -> # Create Socket --
11:56:39.818 ->
ERROR
11:56:40.806 -> # Closing socket --
11:56:40.853 ->
CLOSE OK
11:56:40.899 -> # Create Socket --
11:56:40.946 ->
ERROR
11:56:41.981 -> # Closing socket --
11:56:42.028 ->
CLOSE OK
11:56:42.028 -> # Create Socket --
11:56:42.076 ->
ERROR
11:56:43.065 -> # Closing socket --
11:56:43.113 ->
CLOSE OK
11:56:43.160 -> # Create Socket --
11:56:43.206 ->
ERROR
11:56:44.199 -> # Closing socket --
11:56:44.246 ->
CLOSE OK
11:56:44.292 -> # Create Socket --
11:56:44.340 ->
ERROR
11:56:45.331 -> # Closing socket --
11:56:45.378 ->
CLOSE OK
11:56:45.378 -> # Create Socket --
11:56:45.472 ->
ERROR
11:56:46.457 -> # Closing socket --
11:56:46.505 ->
CLOSE OK
11:56:46.505 -> # Create Socket --
11:56:46.599 ->
ERROR
11:56:47.590 -> # Closing socket --
11:56:47.637 ->
CLOSE OK
11:56:47.637 -> # Create Socket --
11:56:47.684 ->
ERROR
11:56:48.719 -> # Closing socket --
11:56:48.766 ->
CLOSE OK
11:56:48.766 -> # Create Socket --
11:56:48.860 ->
ERROR
11:56:49.850 -> # Closing socket --
11:56:49.898 ->
CLOSE OK
11:56:49.898 -> # Create Socket --
11:56:49.944 ->
ERROR
11:56:50.983 -> # Closing socket --
11:56:51.031 ->
CLOSE OK
11:56:51.031 -> # Create Socket --
11:56:51.078 ->
ERROR
11:56:52.066 -> # Closing socket --
11:56:52.113 ->
CLOSE OK
11:56:52.160 -> # Create Socket --
11:56:52.206 ->
ERROR
11:56:53.196 -> # Closing socket --
11:56:53.243 ->
CLOSE OK
11:56:53.289 -> # Create Socket --
11:56:53.336 ->
ERROR
11:56:54.327 -> # Closing socket --
11:56:54.373 ->
CLOSE OK
11:56:54.420 -> # Create Socket --
11:56:54.467 ->
ERROR
11:56:55.455 -> # Closing socket --
11:56:55.501 ->
CLOSE OK
11:56:55.501 -> # Create Socket --
11:56:55.595 ->
ERROR
11:56:56.575 -> # Closing socket --
11:56:56.622 ->
CLOSE OK
11:56:56.671 -> # Create Socket --
11:56:56.718 ->
ERROR
11:56:57.706 -> # Closing socket --
11:56:57.753 ->
CLOSE OK
11:56:57.800 -> # Create Socket --
11:56:57.847 ->
ERROR
11:56:58.835 -> # Closing socket --
11:56:58.884 ->
CLOSE OK
11:56:58.931 -> # Create Socket --
11:56:58.978 ->
ERROR
11:56:59.965 -> # Closing socket --
11:57:00.011 ->
CLOSE OK
11:57:00.011 -> # Create Socket --
11:57:00.104 ->
ERROR
11:57:01.094 -> # Closing socket --
11:57:01.140 ->
CLOSE OK
11:57:01.140 -> # Create Socket --
11:57:01.235 ->
ERROR
11:57:02.223 -> # Closing socket --
11:57:02.270 ->
CLOSE OK
11:57:02.270 -> # Create Socket --
11:57:02.316 ->
ERROR
11:57:03.351 -> # Closing socket --
11:57:03.397 ->
CLOSE OK
11:57:03.397 -> # Create Socket --
11:57:03.492 ->
ERROR
11:57:04.480 -> # Closing socket --
11:57:04.527 ->
CLOSE OK
11:57:04.527 -> # Create Socket --
11:57:04.574 ->
ERROR
11:57:05.565 -> # Closing socket --
11:57:05.659 ->
CLOSE OK
11:57:05.659 -> # Create Socket --
11:57:05.706 ->
ERROR
11:57:06.735 -> # Closing socket --
11:57:06.782 ->
CLOSE OK
11:57:06.782 -> # Create Socket --
11:57:06.830 ->
ERROR
11:57:07.816 -> # Closing socket --
11:57:07.910 ->
CLOSE OK
11:57:07.910 -> # Create Socket --
11:57:07.957 ->
ERROR
11:57:08.995 -> # Closing socket --
11:57:09.042 ->
CLOSE OK
11:57:09.042 -> # Create Socket --
11:57:09.089 ->
ERROR
11:57:10.079 -> # Closing socket --
11:57:10.126 ->
CLOSE OK
11:57:10.172 -> # Create Socket --
11:57:10.220 ->
ERROR
11:57:11.208 -> # Closing socket --
11:57:11.255 ->
CLOSE OK
11:57:11.302 -> # Create Socket --
11:57:11.350 ->
ERROR
11:57:12.341 -> # Closing socket --
11:57:12.387 ->
CLOSE OK
11:57:12.435 -> # Create Socket --
11:57:12.482 ->
ERROR
11:57:13.469 -> # Closing socket --
11:57:13.516 ->
CLOSE OK
11:57:13.563 -> # Create Socket --
11:57:13.611 ->
ERROR
11:57:14.600 -> # Closing socket --
11:57:14.647 ->
CLOSE OK
11:57:14.694 -> # Create Socket --
11:57:14.741 ->
ERROR
11:57:15.734 -> # Closing socket --
11:57:15.780 ->
CLOSE OK
11:57:15.827 -> # Create Socket --
11:57:15.873 ->
ERROR
11:57:16.862 -> # Closing socket --
11:57:16.909 ->
CLOSE OK
11:57:16.909 -> # Create Socket --
11:57:17.003 ->
ERROR
11:57:17.994 -> # Closing socket --
11:57:18.042 ->
CLOSE OK
11:57:18.042 -> # Create Socket --
11:57:18.088 ->
ERROR
11:57:19.127 -> # Closing socket --
11:57:19.173 ->
CLOSE OK
11:57:19.173 -> # Create Socket --
11:57:19.219 ->
ERROR
11:57:20.253 -> # Closing socket --
11:57:20.300 ->
CLOSE OK
11:57:20.300 -> # Create Socket --
11:57:20.347 ->
ERROR
11:57:21.338 -> # Closing socket --
11:57:21.432 ->
CLOSE OK
11:57:21.432 -> # Create Socket --
11:57:21.479 ->
ERROR
11:57:22.511 -> # Closing socket --
11:57:22.558 ->
CLOSE OK
11:57:22.558 -> # Create Socket --
11:57:22.605 ->
ERROR
11:57:23.593 -> # Closing socket --
11:57:23.640 ->
CLOSE OK
11:57:23.687 -> # Create Socket --
11:57:23.734 ->
ERROR
11:57:24.766 -> # Closing socket --
11:57:24.813 ->
CLOSE OK
11:57:24.813 -> # Create Socket --
11:57:24.859 ->
ERROR
11:57:25.852 -> # Closing socket --
11:57:25.899 ->
CLOSE OK
11:57:25.946 -> # Create Socket --
11:57:25.993 ->
ERROR
11:57:26.979 -> # Closing socket --
11:57:27.025 ->
CLOSE OK
11:57:27.072 -> # Create Socket --
11:57:27.118 ->
ERROR
11:57:28.107 -> # Closing socket --
11:57:28.155 ->
CLOSE OK
11:57:28.202 -> # Create Socket --
11:57:28.249 ->
ERROR
11:57:29.241 -> # Closing socket --
11:57:29.288 ->
CLOSE OK
11:57:29.335 -> # Create Socket --
11:57:29.382 ->
ERROR
11:57:30.371 -> # Closing socket --
11:57:30.417 ->
CLOSE OK
11:57:30.417 -> # Create Socket --
11:57:30.464 ->
ERROR
11:57:31.498 -> # Closing socket --
11:57:31.545 ->
CLOSE OK
11:57:31.545 -> # Create Socket --
11:57:31.640 ->
ERROR
11:57:32.629 -> # Closing socket --
11:57:32.676 ->
CLOSE OK
11:57:32.676 -> # Create Socket --
11:57:32.723 ->
ERROR
11:57:33.761 -> # Closing socket --
11:57:33.808 ->
CLOSE OK
11:57:33.808 -> # Create Socket --
11:57:33.854 ->
ERROR
11:57:34.887 -> # Closing socket --
11:57:34.935 ->
CLOSE OK
11:57:34.935 -> # Create Socket --
11:57:34.981 ->
ERROR
11:57:35.969 -> # Closing socket --
11:57:36.062 ->
CLOSE OK
11:57:36.062 -> # Create Socket --
11:57:36.109 ->
ERROR
11:57:37.142 -> # Closing socket --
11:57:37.190 ->
CLOSE OK
11:57:37.190 -> # Create Socket --
11:57:37.236 ->
ERROR
11:57:38.226 -> # Closing socket --
11:57:38.272 ->
CLOSE OK
11:57:38.319 -> # Create Socket --
11:57:38.365 ->
ERROR
11:57:39.357 -> # Closing socket --
11:57:39.404 ->
CLOSE OK
11:57:39.450 -> # Create Socket --
11:57:39.497 ->
ERROR
11:57:40.521 -> # Closing socket --
11:57:40.568 ->
CLOSE OK
11:57:40.568 -> # Create Socket --
11:57:40.614 ->
ERROR
11:57:41.601 -> # Closing socket --
11:57:41.648 ->
CLOSE OK
11:57:41.695 -> # Create Socket --
11:57:41.742 ->
ERROR
11:57:42.733 -> # Closing socket --
11:57:42.780 ->
CLOSE OK
11:57:42.827 -> # Create Socket --
11:57:42.873 ->
ERROR
11:57:43.862 -> # Closing socket --
11:57:43.909 ->
CLOSE OK
11:57:43.956 -> # Create Socket --
11:57:44.003 ->
ERROR
11:57:44.993 -> # Closing socket --
11:57:45.040 ->
CLOSE OK
11:57:45.087 -> # Create Socket --
11:57:45.133 ->
ERROR
11:57:46.118 -> # Closing socket --
11:57:46.165 ->
CLOSE OK
11:57:46.211 -> # Create Socket --
11:57:46.258 ->
ERROR
11:57:47.253 -> # Closing socket --
11:57:47.300 ->
CLOSE OK
11:57:47.348 -> # Create Socket --
11:57:47.395 ->
ERROR
11:57:48.387 -> # Closing socket --
11:57:48.434 ->
CLOSE OK
11:57:48.434 -> # Create Socket --
11:57:48.481 ->
ERROR
11:57:49.515 -> # Closing socket --
11:57:49.561 ->
CLOSE OK
11:57:49.561 -> # Create Socket --
11:57:49.608 ->
ERROR
11:57:50.600 -> # Closing socket --
11:57:50.647 ->
CLOSE OK
11:57:50.693 -> # Create Socket --
11:57:50.740 ->
ERROR
11:57:51.778 -> # Closing socket --
11:57:51.825 ->
CLOSE OK
11:57:51.825 -> # Create Socket --
11:57:51.872 ->
ERROR
11:57:52.860 -> # Closing socket --
11:57:52.907 ->
CLOSE OK
11:57:52.954 -> # Create Socket --
11:57:53.002 ->
ERROR
11:57:53.994 -> # Closing socket --
11:57:54.041 ->
CLOSE OK
11:57:54.088 -> # Create Socket --
11:57:54.135 ->
ERROR
11:57:55.123 -> # Closing socket --
11:57:55.171 ->
CLOSE OK
11:57:55.171 -> # Create Socket --
11:57:55.267 ->
ERROR
11:57:56.253 -> # Closing socket --
11:57:56.301 ->
CLOSE OK
11:57:56.348 -> # Create Socket --
11:57:56.395 ->
ERROR
11:57:57.386 -> # Closing socket --
11:57:57.434 ->
CLOSE OK
11:57:57.434 -> # Create Socket --
11:57:57.482 ->
ERROR
11:57:58.518 -> # Closing socket --
11:57:58.565 ->
CLOSE OK
11:57:58.565 -> # Create Socket --
11:57:58.612 ->
ERROR
11:57:59.648 -> # Closing socket --
11:57:59.695 ->
CLOSE OK
11:57:59.695 -> # Create Socket --
11:57:59.743 ->
ERROR
11:58:00.781 -> # Closing socket --
11:58:00.828 ->
CLOSE OK
11:58:00.828 -> # Create Socket --
11:58:00.874 ->
ERROR
11:58:01.860 -> # Closing socket --
11:58:01.906 ->
CLOSE OK
11:58:01.953 -> # Create Socket --
11:58:02.000 ->
ERROR
11:58:03.032 -> # Closing socket --
11:58:03.079 ->
CLOSE OK
11:58:03.079 -> # Create Socket --
11:58:03.127 ->
ERROR
11:58:04.117 -> # Closing socket --
11:58:04.164 ->
CLOSE OK
11:58:04.210 -> # Create Socket --
11:58:04.257 ->
ERROR
11:58:05.247 -> # Closing socket --
11:58:05.293 ->
CLOSE OK
11:58:05.339 -> # Create Socket --
11:58:05.386 ->
ERROR
11:58:06.373 -> # Closing socket --
11:58:06.420 ->
CLOSE OK
11:58:06.467 -> # Create Socket --
11:58:06.513 ->
ERROR
11:58:07.503 -> # Closing socket --
11:58:07.550 ->
CLOSE OK
11:58:07.598 -> # Create Socket --
11:58:07.645 ->
ERROR
11:58:08.635 -> # Closing socket --
11:58:08.682 ->
CLOSE OK
11:58:08.729 -> # Create Socket --
11:58:08.776 ->
ERROR
11:58:09.768 -> # Closing socket --
11:58:09.815 ->
CLOSE OK
11:58:09.815 -> # Create Socket --
11:58:09.909 ->
+QIOPEN: 0,0
11:58:10.898 -> AT+QISENDEX=0,52,3836373939373033363536383031312C302C32303232313032333233313135352C302E30302C302E30302C302E30302C302E3030
11:58:11.134 ->
+CEREG: 2,"2CF1","018D4567",9,0,0,"00000000","01011111"
SEND OK
11:58:11.228 -> # Closing socket --
11:58:11.228 ->
CLOSE OK
11:58:11.274 -> # Wait for BC66 to go to sleep --
11:58:13.019 -> CEREG event: +CEREG: 5,"2CF1","0186ED66",9,0,0,"00000000","01011111"
11:58:24.327 -> Deep sleep event!
11:58:26.213 -> -> MCU to sleep
11:59:27.620 -> -> MCU waking up
11:59:28.370 -> # Wait for BC66 wake up --
11:59:28.370 -> Send interrupt to BC66 PSM_EINT pin
11:59:28.793 -> CEREG event: +CEREG: 5,"2CF1","0186ED66",9,0,0,"00000000","01011111"
11:59:28.839 -> Wake up event!
11:59:34.583 -> Connected!
11:59:34.583 -> # Create Socket --
11:59:34.630 ->
ERROR
11:59:35.664 -> # Closing socket --
11:59:35.711 ->
CLOSE OK
11:59:35.711 -> # Create Socket --
11:59:35.758 ->
ERROR
11:59:36.793 -> # Closing socket --
11:59:36.840 ->
CLOSE OK
11:59:36.840 -> # Create Socket --
11:59:36.886 ->
ERROR
11:59:37.929 -> # Closing socket --
11:59:37.929 ->
CLOSE OK
11:59:37.976 -> # Create Socket --
11:59:38.024 ->
ERROR
11:59:39.017 -> # Closing socket --
11:59:39.064 ->
CLOSE OK
11:59:39.112 -> # Create Socket --
11:59:39.160 ->
ERROR
11:59:40.149 -> # Closing socket --
11:59:40.196 ->
CLOSE OK
11:59:40.243 -> # Create Socket --
11:59:40.290 ->
ERROR
11:59:41.278 -> # Closing socket --
11:59:41.325 ->
CLOSE OK
11:59:41.325 -> # Create Socket --
11:59:41.420 ->
ERROR
11:59:42.414 -> # Closing socket --
11:59:42.461 ->
CLOSE OK
11:59:42.461 -> # Create Socket --
11:59:42.509 ->
ERROR
11:59:43.547 -> # Closing socket --
11:59:43.594 ->
CLOSE OK
11:59:43.594 -> # Create Socket --
11:59:43.640 ->
ERROR
11:59:44.635 -> # Closing socket --
11:59:44.682 ->
CLOSE OK
11:59:44.728 -> # Create Socket --
11:59:44.775 ->
ERROR
11:59:45.766 -> # Closing socket --
11:59:45.813 ->
CLOSE OK
11:59:45.859 -> # Create Socket --
11:59:45.906 ->
ERROR
11:59:46.894 -> # Closing socket --
11:59:46.941 ->
CLOSE OK
11:59:46.989 -> # Create Socket --
11:59:47.036 ->
ERROR
11:59:48.021 -> # Closing socket --
11:59:48.067 ->
CLOSE OK
11:59:48.115 -> # Create Socket --
11:59:48.162 ->
ERROR
11:59:49.152 -> # Closing socket --
11:59:49.198 ->
CLOSE OK
11:59:49.245 -> # Create Socket --
11:59:49.291 ->
ERROR
11:59:50.281 -> # Closing socket --
11:59:50.328 ->
CLOSE OK
11:59:50.328 -> # Create Socket --
11:59:50.421 ->
ERROR
11:59:51.407 -> # Closing socket --
11:59:51.454 ->
CLOSE OK
11:59:51.501 -> # Create Socket --
11:59:51.548 ->
ERROR
11:59:52.537 -> # Closing socket --
11:59:52.585 ->
CLOSE OK
11:59:52.585 -> # Create Socket --
11:59:52.632 ->
ERROR
11:59:53.667 -> # Closing socket --
11:59:53.714 ->
CLOSE OK
11:59:53.714 -> # Create Socket --
11:59:53.809 ->
ERROR
11:59:54.800 -> # Closing socket --
11:59:54.847 ->
CLOSE OK
11:59:54.847 -> # Create Socket --
11:59:54.894 ->
ERROR
11:59:55.930 -> # Closing socket --
11:59:55.977 ->
CLOSE OK
11:59:55.977 -> # Create Socket --
11:59:56.025 ->
ERROR
11:59:57.009 -> # Closing socket --
11:59:57.103 ->
CLOSE OK
11:59:57.103 -> # Create Socket --
11:59:57.151 ->
ERROR
11:59:58.138 -> # Closing socket --
11:59:58.231 ->
CLOSE OK
11:59:58.231 -> # Create Socket --
11:59:58.278 ->
ERROR
11:59:59.270 -> # Closing socket --
11:59:59.318 ->
CLOSE OK
11:59:59.364 -> # Create Socket --
11:59:59.411 ->
ERROR
12:00:00.394 -> # Closing socket --
12:00:00.441 ->
CLOSE OK
12:00:00.488 -> # Create Socket --
12:00:00.535 ->
ERROR
12:00:01.524 -> # Closing socket --
12:00:01.572 ->
CLOSE OK
12:00:01.619 -> # Create Socket --
12:00:01.664 ->
ERROR
12:00:02.654 -> # Closing socket --
12:00:02.702 ->
CLOSE OK
12:00:02.749 -> # Create Socket --
12:00:02.796 ->
ERROR
12:00:03.783 -> # Closing socket --
12:00:03.830 ->
CLOSE OK
12:00:03.878 -> # Create Socket --
12:00:03.925 ->
ERROR
12:00:04.915 -> # Closing socket --
12:00:04.962 ->
CLOSE OK
12:00:04.962 -> # Create Socket --
12:00:05.055 ->
ERROR
12:00:06.043 -> # Closing socket --
12:00:06.090 ->
CLOSE OK
12:00:06.136 -> # Create Socket --
12:00:06.184 ->
ERROR
12:00:07.173 -> # Closing socket --
12:00:07.219 ->
CLOSE OK
12:00:07.219 -> # Create Socket --
12:00:07.266 ->
ERROR
12:00:08.297 -> # Closing socket --
12:00:08.345 ->
CLOSE OK
12:00:08.345 -> # Create Socket --
12:00:08.439 ->
ERROR
12:00:09.428 -> # Closing socket --
12:00:09.475 ->
CLOSE OK
12:00:09.475 -> # Create Socket --
12:00:09.522 ->
ERROR
12:00:10.558 -> # Closing socket --
12:00:10.605 ->
CLOSE OK
12:00:10.605 -> # Create Socket --
12:00:10.652 ->
ERROR
12:00:11.687 -> # Closing socket --
12:00:11.735 ->
CLOSE OK
12:00:11.735 -> # Create Socket --
12:00:11.829 ->
+QIOPEN: 0,0
12:00:12.816 -> AT+QISENDEX=0,55,3836373939373033363536383031312C312C32303232313032333233313135352C302E37362C2D362E31342C31362E36312C39392E3939
12:00:12.956 ->
ERROR
12:00:13.947 -> AT+QISENDEX=0,1,78
12:00:14.088 ->
+CEREG: 2,"2CF1","0186ED66",9,0,0,"00000000","01011111"
SEND OK
12:00:14.181 -> # Closing socket --
12:00:14.181 ->
CLOSE OK
12:00:14.228 -> # Wait for BC66 to go to sleep --
12:00:15.780 -> CEREG event: +CEREG: 5,"2CF1","018D4567",9,0,0,"00000000","01011111"
12:00:26.370 -> Deep sleep event!
12:00:29.202 -> -> MCU to sleep
12:01:30.565 -> -> MCU waking up
12:01:31.322 -> # Wait for BC66 wake up --
12:01:31.369 -> Send interrupt to BC66 PSM_EINT pin
12:01:31.746 -> CEREG event: +CEREG: 5,"2CF1","018D4567",9,0,0,"00000000","01011111"
12:01:31.793 -> Wake up event!
12:01:37.543 -> Connected!
12:01:37.543 -> # Create Socket --
12:01:37.590 ->
ERROR
12:01:38.578 -> # Closing socket --
12:01:38.674 ->
CLOSE OK
12:01:38.674 -> # Create Socket --
12:01:38.721 ->
ERROR
12:01:39.714 -> # Closing socket --
12:01:39.761 ->
CLOSE OK
12:01:39.808 -> # Create Socket --
12:01:39.855 ->
ERROR
12:01:40.845 -> # Closing socket --
12:01:40.892 ->
CLOSE OK
12:01:40.940 -> # Create Socket --
12:01:40.986 ->
ERROR
12:01:41.976 -> # Closing socket --
12:01:42.022 ->
CLOSE OK
12:01:42.022 -> # Create Socket --
12:01:42.115 ->
ERROR
12:01:43.103 -> # Closing socket --
12:01:43.150 ->
CLOSE OK
12:01:43.150 -> # Create Socket --
12:01:43.244 ->
ERROR
12:01:44.232 -> # Closing socket --
12:01:44.280 ->
CLOSE OK
12:01:44.280 -> # Create Socket --
12:01:44.326 ->
ERROR
12:01:45.361 -> # Closing socket --
12:01:45.409 ->
CLOSE OK
12:01:45.409 -> # Create Socket --
12:01:45.504 ->
ERROR
12:01:46.490 -> # Closing socket --
12:01:46.537 ->
CLOSE OK
12:01:46.537 -> # Create Socket --
12:01:46.584 ->
ERROR
12:01:47.618 -> # Closing socket --
12:01:47.665 ->
CLOSE OK
12:01:47.665 -> # Create Socket --
12:01:47.712 ->
ERROR
12:01:48.746 -> # Closing socket --
12:01:48.792 ->
CLOSE OK
12:01:48.792 -> # Create Socket --
12:01:48.838 ->
ERROR
12:01:49.872 -> # Closing socket --
12:01:49.920 ->
CLOSE OK
12:01:49.920 -> # Create Socket --
12:01:49.967 ->
ERROR
12:01:51.002 -> # Closing socket --
12:01:51.049 ->
CLOSE OK
12:01:51.049 -> # Create Socket --
12:01:51.096 ->
ERROR
12:01:52.084 -> # Closing socket --
12:01:52.131 ->
CLOSE OK
12:01:52.177 -> # Create Socket --
12:01:52.224 ->
ERROR
12:01:53.212 -> # Closing socket --
12:01:53.306 ->
CLOSE OK
12:01:53.306 -> # Create Socket --
12:01:53.353 ->
ERROR
12:01:54.341 -> # Closing socket --
12:01:54.388 ->
CLOSE OK
12:01:54.435 -> # Create Socket --
12:01:54.482 ->
ERROR
12:01:55.467 -> # Closing socket --
12:01:55.515 ->
CLOSE OK
12:01:55.562 -> # Create Socket --
12:01:55.608 ->
ERROR
12:01:56.600 -> # Closing socket --
12:01:56.647 ->
CLOSE OK
12:01:56.694 -> # Create Socket --
12:01:56.740 ->
ERROR
12:01:57.731 -> # Closing socket --
12:01:57.778 ->
CLOSE OK
12:01:57.778 -> # Create Socket --
12:01:57.872 ->
ERROR
12:01:58.862 -> # Closing socket --
12:01:58.909 ->
CLOSE OK
12:01:58.957 -> # Create Socket --
12:01:59.005 ->
ERROR
12:01:59.994 -> # Closing socket --
12:02:00.042 ->
CLOSE OK
12:02:00.042 -> # Create Socket --
12:02:00.089 ->
ERROR
12:02:01.121 -> # Closing socket --
12:02:01.167 ->
CLOSE OK
12:02:01.167 -> # Create Socket --
12:02:01.262 ->
ERROR
12:02:02.253 -> # Closing socket --
12:02:02.300 ->
CLOSE OK
12:02:02.300 -> # Create Socket --
12:02:02.347 ->
ERROR
12:02:03.385 -> # Closing socket --
12:02:03.432 ->
CLOSE OK
12:02:03.432 -> # Create Socket --
12:02:03.479 ->
ERROR
12:02:04.469 -> # Closing socket --
12:02:04.516 ->
CLOSE OK
12:02:04.563 -> # Create Socket --
12:02:04.610 ->
ERROR
12:02:05.597 -> # Closing socket --
12:02:05.690 ->
CLOSE OK
12:02:05.690 -> # Create Socket --
12:02:05.737 ->
ERROR
12:02:06.727 -> # Closing socket --
12:02:06.774 ->
CLOSE OK
12:02:06.821 -> # Create Socket --
12:02:06.868 ->
ERROR
12:02:07.860 -> # Closing socket --
12:02:07.908 ->
CLOSE OK
12:02:07.955 -> # Create Socket --
12:02:08.002 ->
ERROR
12:02:08.995 -> # Closing socket --
12:02:09.041 ->
CLOSE OK
12:02:09.041 -> # Create Socket --
12:02:09.136 ->
ERROR
12:02:10.130 -> # Closing socket --
12:02:10.177 ->
CLOSE OK
12:02:10.177 -> # Create Socket --
12:02:10.224 ->
ERROR
12:02:11.255 -> # Closing socket --
12:02:11.301 ->
CLOSE OK
12:02:11.301 -> # Create Socket --
12:02:11.348 ->
ERROR
12:02:12.384 -> # Closing socket --
12:02:12.431 ->
CLOSE OK
12:02:12.431 -> # Create Socket --
12:02:12.478 ->
ERROR
12:02:13.468 -> # Closing socket --
12:02:13.515 ->
CLOSE OK
12:02:13.562 -> # Create Socket --
12:02:13.609 ->
ERROR
12:02:14.644 -> # Closing socket --
12:02:14.691 ->
CLOSE OK
12:02:14.691 -> # Create Socket --
12:02:14.737 ->
ERROR
12:02:15.727 -> # Closing socket --
12:02:15.774 ->
CLOSE OK
12:02:15.820 -> # Create Socket --
12:02:15.868 ->
ERROR
12:02:16.856 -> # Closing socket --
12:02:16.950 ->
CLOSE OK
12:02:16.950 -> # Create Socket --
12:02:16.997 ->
ERROR
12:02:17.985 -> # Closing socket --
12:02:18.033 ->
CLOSE OK
12:02:18.079 -> # Create Socket --
12:02:18.126 ->
ERROR
12:02:19.116 -> # Closing socket --
12:02:19.163 ->
CLOSE OK
12:02:19.210 -> # Create Socket --
12:02:19.255 ->
ERROR
12:02:20.251 -> # Closing socket --
12:02:20.298 ->
CLOSE OK
12:02:20.298 -> # Create Socket --
12:02:20.345 ->
ERROR
12:02:21.380 -> # Closing socket --
12:02:21.427 ->
CLOSE OK
12:02:21.427 -> # Create Socket --
12:02:21.521 ->
ERROR
12:02:22.504 -> # Closing socket --
12:02:22.551 ->
CLOSE OK
12:02:22.551 -> # Create Socket --
12:02:22.644 ->
ERROR
12:02:23.631 -> # Closing socket --
12:02:23.679 ->
CLOSE OK
12:02:23.679 -> # Create Socket --
12:02:23.772 ->
+QIOPEN: 0,0
12:02:24.766 -> AT+QISENDEX=0,55,3836373939373033363536383031312C322C32303232313032333233313135352C302E35362C2D362E31342C31382E34352C39392E3939
12:02:24.907 ->
ERROR
12:02:25.942 -> AT+QISENDEX=0,1,78
12:02:26.036 ->
SEND OK
12:02:26.132 -> # Closing socket --
12:02:26.132 ->
CLOSE OK
12:02:26.179 -> # Wait for BC66 to go to sleep --
12:02:28.901 -> CEREG event: +CEREG: 5,"2CF1","018D4567",9,0,0,"00000000","01011111"
12:02:39.574 -> Deep sleep event!
12:02:41.131 -> -> MCU to sleep
12:03:42.519 -> -> MCU waking up
12:03:43.274 -> # Wait for BC66 wake up --
12:03:43.321 -> Send interrupt to BC66 PSM_EINT pin
12:03:46.465 -> Send interrupt to BC66 PSM_EINT pin
12:03:49.688 -> Send interrupt to BC66 PSM_EINT pin
12:03:52.865 -> Send interrupt to BC66 PSM_EINT pin
12:03:56.084 -> Send interrupt to BC66 PSM_EINT pin
12:03:59.262 -> Send interrupt to BC66 PSM_EINT pin
12:04:02.461 -> Send interrupt to BC66 PSM_EINT pin
12:04:05.690 -> Send interrupt to BC66 PSM_EINT pin
12:04:08.879 -> Send interrupt to BC66 PSM_EINT pin
12:04:12.067 -> Send interrupt to BC66 PSM_EINT pin
12:04:16.077 -> Send interrupt to BC66 PSM_EINT pin
12:04:19.289 -> Send interrupt to BC66 PSM_EINT pin
12:04:22.497 -> Send interrupt to BC66 PSM_EINT pin
12:04:25.686 -> Send interrupt to BC66 PSM_EINT pin
12:04:28.885 -> Send interrupt to BC66 PSM_EINT pin
12:04:32.070 -> Send interrupt to BC66 PSM_EINT pin
12:04:35.251 -> Send interrupt to BC66 PSM_EINT pin
12:04:38.484 -> Send interrupt to BC66 PSM_EINT pin
12:04:41.672 -> Send interrupt to BC66 PSM_EINT pin
12:04:44.880 -> Send interrupt to BC66 PSM_EINT pin
12:04:48.073 -> Send interrupt to BC66 PSM_EINT pin
