Hi, I’m new at MQTT and AT commands in a BC66.
Actually, I’m using a NB-IoT module of OLIMEX:
- NB-IOT DEVELOPMENT BOARD WITH BC-66 MODULE AND PROGRAMMER
I already read a bit about all Manual AT commands in BC66 (v2.2) (here)
I think that I should configure first some AT configurations before create a MQTT connection client to a broker.
Since I don’t know which commands and their sequence I should send to the module, I found a guide (here) which explains how to “Attach to NB-IoT network”.
The parameters about SIM operator (Altice/MEO) are the following:
- Codes MCC MNC = 268 06
- APN = internetm2m
- Username = (none)
- Passowrd = (none)
In this guide, there is at the end of the page a full sequence of commands that I used.
THE PROBLEM that I had was after restart the module, I supposedly should receive a “+IP: xx.xx.xx.xx” from the network in less that 1 minute but I do not receive any information.
Can someone try to explain or help me I this process?
Here are the sequence of AT commands that I used.
Disable Sleep Mode:
AT+QSCLK=0
Enable echo to console
ATE1
Set mobile operation band
AT+QBAND=1,20
Swicht off radio functionality
AT+CFUN=0
Setup the default APN
AT+QCGDEFCONT=“IP”,“internetm2m”
Configure operator manually
AT+COPS=1,2,“26806”
Restart device
AT+QRST=1
Disable Sleep Mode:
AT+QSCLK=0
ATE1
Wait 45 sec for a +IP report that i did not receive!
So, I checked Extended Signal Quality (AT+CESQ) and the result was:
+CESQ: 2,0,255,255,20,23
These parameters with value “255” are about “Received signal code power” and “Ec/No” which means that they are “255 Not known or not detectable”
Could It means that my SIM card does not support NB-IoT?
Thanks a lot!
