I understand that, but when I set n to 3 I am expecting 7 fields from the response delimited with 6 commas.
I get response with 7 commas which is inconsistent with result code explained in AT Commands Manual.
When sending AT+CEREG? read command, I received the response +CEREG: 3,0, , , , ,0,0
First value is n, in this case 3
Comma
Second value is stat, in this case 0
Comma
Third value is empty (this would be tac)
Comma
Fourth value is empty (this would be ci)
Comma
Fifth value is empty (this would be AcT) Comma Sixth value is empty (???) // This is where I expect cause_type
Comma
Seventh value is 0
Comma
Eight value is 0
So I am having an extra comma there, or am I missing something?
You are mixing response to AT+CEREG? and +CEREG unsolicited message. The former has one more field - current CEREG settings, while the latter does not have it. In the AT commands manual this value is referred as <n>.
So you first example is:
AT+CEREG?
+CEREG: ,,,…
and the second is:
+CEREG: ,,…
It is a bit confusing, but to properly parse +CEREG message you have to count number of fields and then you know which one to use. Otherwise you may get (in very rare case) two +CEREG messages as a reply to AT+CEREG? - one being the reply and the other being unsolicited message. This could happen if just in that moment network registration status changes.
Or, you could simplify it by looking for quotes in TAC and cellid fields.
Here is the excerpt from the document that is preceeding the one you’ve posted:
Coming back to my original question, even if that was URC, it would make less sense: 3 would be stat value (REGISTRATION_DENIED) which I’ve never received. and tac would be 0 which is not a string.
Using this table, can you parse this in any reasonable way? Using your logic, number of commas would lead me to parse this as n=4 or n=5 URC, but even then parameters don’t fit.
I’m pretty sure this is a normal response when n=3, but this comma should not be there.
@dev1 You’re right, I haven’t noticed it so far. When TAC/cellid are not filled, there is one more comma than expected. What FW version are you using? This issue seems to be fixed in BC66NBR01A11, even though it is not mentioned in release notes.
I don’t know which exact version is on the module, but AT+CGSN=3 returns value 10. If that’s not the latest, version where can I obtain FW you’ve mentioned?
