Recently the time zone has been updated because of DST however the AT+CCLK? Command still returns the incorrect time zone unless I reset and re-register the module. Should I be running an ‘extra’ command prior to AT+CCLK? perhaps?
Hi Lukegalea
AT + CCLK? What is obtained is the time issued by the base station, and the time will only be calibrated when re-entering the network.
Re-entering the network suggests re-registration?
How do you suggest to deal with DST then?
Hi Lukegalea
【Abner】You can only actively synchronize the time manually.
Or module AT+CFUN=0, AT+CFUN=1 to let the module re-enter the network to get the time.
