Hi, we are evaluating the bc65 module using the BC65-TE-B eval board, but are having trouble connecting. The documentation is a little bit sparse on this, so I wanted to check I’m understanding correctly:
I’ve tried:
connecting under linux to /dev/ttyUSB0 with 9600 8N1, SIM card present, switch set to “main usb to uart”, device does not respond to AT, pressing RESET or POWERKEY button don’t change.
connecting via a true 3V3 uart via Arduino connector, powerkey pulled to ground, switch set to “main uart to mcu”. Same behavior.
The manual doesn’t provide any more information. Is there anything else I need to do to actiate the module? I there a complete Windows program to initiate communication to test to make sure the devboard is not broken? Where can I download the Windows programms (QFlash, LogCapture)?
Thank you!
