Hello, dear colleagues!
I got the opportunity to test the BC-95G. Can I use iperf and wireshark to estimate bandwidth? If I can, then how do I set up QNavigator to work with the iperf?
Thank you in advance!
Hi Mikhvikt
Cannot use wireshark and iperf to test bandwidth, you can use CMW500 instrument to test.
Thanks for the answer. Are there any other options for evaluating packet data?
Hi Mikhvikt
You can always send data through TCP/UDP to test the data transmission rate.
Hi Abner
Please tell me where to look at the manual for setting up tcp/udp?
Hi Mikhvikt
There are routines in the AT command set.
