Aw 1000 router telephone port drivers (rj11)
Subject: Request for Telephone Port (RJ11) Drivers for Arcadyan AW1000 Router
Hello everyone,
I am currently working on developing custom firmware for the Arcadyan AW1000 router and would like to enable the RJ11 telephone port functionality. However, I have not been able to find the necessary drivers for the telephone port.
Could anyone please help me with the drivers for the telephone (RJ11) port on the Arcadyan AW1000? Alternatively, if you have any guidance or resources on how to enable and configure this feature within custom firmware (OpenWrt/ImmortalWrt), I would greatly appreciate it.
Thank you very much for your support and help!
Only if have the source code of the firmware of the OpenWrt that you can add any driver. If you just need how to enable the RJ11, it is better to ask the owner of the firmware of the OpenWrt.
I also look for drivers/firmware sofware for the AW1000 Arcadyne 5g SIM router. My text:
Arcadyan AW1000 / Telstra 5G modem, OpenWrt 23.05-SNAPSHOT.
The RJ11/FXS hardware appears in device-tree and on SPI:
/sys/bus/spi/devices/spi0.0/modalias = spi:si3217x
/sys/bus/spi/devices/spi0.0/of_node/compatible = si3217x
/sys/bus/spi/devices/spi0.0/driver = No driver bound
Device-tree also contains:
slic_reset
slic_interrupt
No si3217x/proslic/slic/dahdi/fxs kernel module is present in /lib/modules.
Do you know of any AW1000 build, patch, or vendor driver that enables the RJ11/FXS ports?
Best regards
Joergen
vestergaardjv@gmail.com
