Hello ,
I wrote a Python program for the BG95 module, and it works correctly. However, I need to make this file run automatically after the module powers on, but I haven’t found a way to do that. Any suggestions?
Hello ,
hi
You can name the script main.py. The module will automatically execute the main.py script when powered on.
is the same method is used for Quectel EC200UCN AC module?
hi,melwin
yes, when the script is named main.py, the module automatically runs the script after it is powered on.
By the way, Could you tell me the version of firmware you are using?
(post deleted by author)
