The RSRP results jump to -300 and lower if the actual RSRP is stronger than ~-52. This can be seen when the RSRP ramps up to ~-52 and ramps down below ~-52
FIrmware:
RM502QAEAAR13A04M4G_01.201.01.201
Is this expected behavior if the signal is strong? The documentation shows the range to be -140 to -44
Hi Silvia, is there a new firmware build that includes the fix that I tested with? Also, looking to obtain ADB key. The result from AT+ADBKEY: 18253552
