I’m using the M66 module. In my application i want to use the internal TCP/IP stack.
According to the application note, following sequence will activate the PDP context:
sequence 1:
AT+QIREGAPP
AT+QIACT
There is also another possibility to activate a self-defined PDP context
sequence 2:
AT+CGCONT
AT+CGATT
AT+CGACT
In my application I need to observe the status of the PDP context. It seems to me that with sequence 1 I’m not getting the unsolicited event reporting of AT+CGEREP. Only if i explicitly define the context like in sequence 2 I will get them.
Is there any possiblity to get the event reporting of AT+CGEREP with sequence 1? And also can you explain which context is being used with QIREGAPP? Somewhere I read that it is kind of a default context, but I’m not sure. Can I use a self-defined context with QIREGAPP?
Thank you!
