I have bought a BG95-M3 module, which I am still waiting to receive, but I have been looking at the AT command documents and I have a doubt for the command AT+QIOPEN.
In the past I have been working with the BC95-GV module, which has an equivalent AT command named AT+NSOCR. In the case of AT+NSOCR I do not need to introduce the IP of the address of the remote server; however, it seems that with AT+QIOPEN the IP adress needs to be introduced.
Is it equivalent using AT+NSOCR=DGRAM,17,4587,1 or using AT+QIOPEN=1,1,“UDP SERVICE”,“127.0.0.1”,0,4587,0? If not how should I write the AT+QIOPEN command?
Thanks and best regards,
Asier
