AT+QHTTPPUT Support in MC60E Module
Dear Quectel Support Team,
I am currently working with the MC60E-CA-BLE module, specifically the firmware version MC60ECAR01A03, and I would like to confirm whether the AT+QHTTPPUT command is supported in this version.
Could you kindly let me know:
  1. Whether AT+QHTTPPUT is available in this firmware?
  2. If not, is there an alternative way to perform HTTP PUT requests using either AT commands or OpenCPU SDK?
  3. Is there any updated firmware or SDK that includes this functionality?
I would greatly appreciate your guidance, and if available, please also share the latest AT command manual, OpenCPU SDK, and tools required to enable HTTPS or extended HTTP features on this module.
Thank you for your support.
Hi
Do you consider use TCP instead of HTTP, because i can only find TCP Manual with GSM module.
