kbhate
#1
I am using BG95-M1 module. Firmware version is BG95M1LAR02A02.
I have observed that response of command AT+QFWRITE doesn’t start with \r\n.
Thus, response is like this : +QFWRITE: 3,3\r\n\r\nOK\r\n
Other commands, for example, AT+CEREG? respond as per expectation where response starts and ends with \r\n.
So, can anyone explain why response of AT+QFWRITE doesn’t start with \r\n ?
actually , i am not udnerstand what your means ,
Even , AT+CEREG? cmd and ATE cmd , it does not begin with \r\n
i attached it as below
i attached the HEx format also
OD 0A means " /r/n"
any more confusion , pls send email to support@quectel.com
I double check this with R&D
Pls seen the below comments .
Because this repsonse include multi line .
kbhate
#5
Yes, correct. Sorry, I was not much aware about how multi-line responses are presented.
No problem with AT+QFWRITE response.
