Hi everyone,
I am trying to use gpsOneXTRA function and following the example steps in Quectel_EC2x&EG9x&EG2x-G&EM05_Series_GNSS_Application_Note_V1.3, and the module I used is EG-25G.
When I first used AT+QFUPL command, it responed CONNECT and stopped for a while, and then no more reponse from the module.
After that , I tried AT+QFUPL again, and the module responsed an error code as 407.
After the error code, I used AT+QFLST="RAM:* to check the memory and the response was +QFLST: “RAM:xtra2.bin”,1798. The size of the file is wrong.
To contiue the steps for gpsOneXTRA, I need to solve these problems first.
The following questions are confused me.
- Do I need to under the open sky when using AT+QFLST?
- Do I need to first download the file to my PC before using AT+QFLST?
- Do QCOM is still needed if using AT+QFLST?
- If pre-download and QCOM are both needed, what is the sequence of these three operations?
I will really appreciate for suggestions.
