Hi, why is the lte_rssi parameter on this command for the EG21-G positive? With the BG96 I have this response:
AT+QCSQ
+QCSQ: "CAT-M1",-91,-129,67,-20
That makes sense to me but then I have this response with the EG21-G:
AT+QCSQ
+QCSQ: "LTE",77,-116,76,-17
Why is it 77 positive? Should I apply any conversion?
Dear @Rafa_Hernandez ,
Thank you for reaching out.
On EG21-G, the LTE RSSI field in AT+QCSQ is reported as a positive magnitude (i.e., the absolute value), not as a signed dBm number. That’s why you see 77 instead of -77.
So you can interpret it like this for LTE on EG21-G:
LTE RSSI (dBm) = -lte_rssi when it is shown as a positive value
Example: 77 → -77 dBm
The other LTE values in the same line are already in their normal signed form and should be used as-is:
RSRP: -116 dBm
SINR: 76
RSRQ: -17 dB
So yes, for your EG21-G output, just treat the first LTE number as -77 dBm; no other conversion is needed.
Best Regards,
Aghelan
@aghelan_loga thanks for your reply. Regarding the same command for the sinr parameter the BG96 documentation said this:
Logarithmic value of SINR. Values are in 1/5th of a dB. The range is 0–250 which translates to -20dB – +30dB
What does this mean and how can I do de conversion?
thanks
Thank you for reaching out again.
That description means the SINR value returned by AT+QCSQ is not directly in dB. It’s an encoded number with two parts:
- Resolution: each step is 1/5 dB (0.2 dB)
- Offset: the scale starts at −20 dB
So the conversion to real SINR in dB is:
SINR(dB) = (sinr_value / 5) − 20
Example:
- sinr_value = 0 → (0/5) − 20 = −20 dB
- sinr_value = 250 → (250/5) − 20 = +30 dB
- Your earlier CAT-M1 example: sinr_value = 67 → (67/5) − 20 = 13.4 − 20 = −6.6 dB
In code, just compute sinr_db = sinr_value * 0.2 - 20.
If you ever see a value outside the documented range (or a special “invalid” placeholder), treat it as “not available” rather than converting it.
Best Regards,
Aghelan
