Hi everyone,
I recently succeed to use my module as a modem on windows 10 but i still have some troubles. Indeed, when i try to use it as LTE only with the command above, the system return me a net_stat led in idle mode and none connection. I tried different command to look if services where on but i doubt of that, the at+qeng=“servingcell” returns me “servingcells” and “SEARCH” and when i try a AT+QNWINFO, it returns me “NOSERVICE”
i used the following commands to make it works
AT+QCFG="usbnet",1
AT+QCFG="nwscanmode",0,1
AT+QCFG="band",0,44,0,1
AT+QIACT=1
Notice that the only technology that works on is the GSM (function 1 on nwscanmode).
Do you have an idea to make it works ?
