AT+QCFG Descriptions
i use the EG91-E. When i type
AT+QCFG=?
+QCFG: “gprsattach”,(0,1)
+QCFG: “nwscanmode”,(0-8),(0,1)
+QCFG: “nwscanseq”,(00-0102030405),(0,1)
+QCFG: “servicedomain”,(0,1,2),(0,1)
+QCFG: “roamservice”,(1,2,255),(0,1)
+QCFG: “roamserviceex”,(0-3)
+QCFG: “band”,(0-200),(0-7FFFFFFFFFFFFFFF),(0-7FFFFFFFFFFFFFFF),(0,1)
+QCFG: “rrc”,(0-4)
+QCFG: “cops_no_mode_change”,(0-1)
+QCFG: “urc_cause_support”,(0-63)
+QCFG: “assign_plmn_in_limit_search”,(0,1),“plmn”
+QCFG: “disable_backoff_lte”,(0-1)
+QCFG: “sort_available_plmn”,(0,1)
+QCFG: “msc”,(0-2)
+QCFG: “sgsn”,(0-2)
+QCFG: “hsdpacat”,(6,8,10-24)
+QCFG: “hsupacat”,(5,6)
+QCFG: “pdp/duplicatechk”,(0,1)
+QCFG: “tdscsq”,(0,1)
+QCFG: “airplanecontrol”,(0,2)
+QCFG: “airplane”,(0-3)
+QCFG: “map_rej_cause7_to_cause14”,(0,1)
+QCFG: “ledmode”,(0-2)
+QCFG: “ehrpd”,(0,7)
+QCFG: “usbid”,,
+QCFG: “usbee”,
+QCFG: “usbnet”,<0-3>
+QCFG: “usbmode”,(0,1)
+QCFG: “usbcfg”,,,,,<at_port>,,,,
+QCFG: “usbenum/seoctl”,(0,1)
+QCFG: “spi/set”,(0-2)
+QCFG: “urc/ri/ring”,(“off”,“pulse”,“always”,“auto”,“wave”),(1-2000),(1-10000),(1-10000),(“off”,“on”),(1-5)
+QCFG: “urc/ri/smsincoming”,(“off”,“pulse”,“always”),(1-2000),(1-5)
+QCFG: “urc/ri/other”,(“off”,“pulse”),(1-2000),(1-5)
+QCFG: “urc/ri/restart”,(0,1)
+QCFG: “risignaltype”,(“respective”,“physical”)
+QCFG: “urc/delay”,(0,1)
+QCFG: “urcdelay”,(0,1),(0-10000)
+QCFG: “agps/string”,(0,1)
+QCFG: “cdmaruim”,(0,1)
+QCFG: “cmux/urcport”,(0-4)
+QCFG: “ModemRstLevel”,(0,1)
+QCFG: “ApRstLevel”,(0,1)
+QCFG: “noauthcheck”,(0,1)
+QCFG: “nwscanmodeex”,(1-63)
+QCFG: “oostimer”,,,
+QCFG: “diversity”,(0-1)
+QCFG: “ppp/termframe”,(0,1)
+QCFG: “ppp/v4v6”,(0,1)
+QCFG: “bootup”,,(0,1)
+QCFG: “nwoptmz/acq”,(0,1),(60-16777200)
+QCFG: “ims”,(0-2)
+QCFG: “pcmclk”,(0,1)
+QCFG: “tone/incoming”,(0,3)
+QCFG: “sim/recovery”,(3-300),(0,5-300),(0,300)
+QCFG: “rssi”,(0-20)
+QCFG: “ltesms/format”[,(0,1)]
+QCFG: “amrcodec”,(0-255)
+QCFG: “frhrcodec”,(0-7)
+QCFG: “apready”,(0,1),(0,1),(100-3000)
+QCFG: “sleepind/level”,(0,1)
+QCFG: “wakeupin/level”,(0,1),(0,1)
+QCFG: “urc/cache”,(0,1)
+QCFG: “thermal/modem”[,,,]
+QCFG: “thermal/limit_rates”[,]
+QCFG: “thermal/txpwrlmt”[,<on_off>,,<temp_threshold>,,<trig_cnt>,<crl_cnt>]
+QCFG: “sim/softsimmode”,(0,9)
+QCFG: “instrument/connection”,(0~4,6~7)
+QCFG: “codec/powsave”,(0,1)
+QCFG: “lte/bandprior”,(1-43),(1-43),(1-43)
+QCFG: “qmisync”,(0,1)
+QCFG: “disrplmn”,(0,1),(0,1)
+QCFG: “vts/async”,(0,1)
+QCFG: “urc/ri/pin”,(“uart_ri”,“uart_dcd”)
+QCFG: “stkauto/setupmenutr”,(0,1)
+QCFG: “iproute_enable”,(0,1)
+QCFG: “imsreg/iptype”,(0,1)
+QCFG: “multi_ip_package”,,<package_max_len>,<package_max_count_in_queue>,
+QCFG: “apn/blocked”,(0,1),(0,1)
+QCFG: “pktsize”
+QCFG: “redir/3gtolte”,(0,1),(0,1),(0,1)
+QCFG: “qcautoconnect”,(0,1)
+QCFG: “volte_disable”,(0,1)
+QCFG: “sim/clk_freq”,(0,1)
+QCFG: “sim/features_status_list”,(0-62),(0,1)
+QCFG: “sim/uim_config_params”,(0-79),(0,1)
+QCFG: “writedata/modem”,,,<data_size>
+QCFG: “writedata/ap”,,,<data_size>
+QCFG: “roaming/voicecall”,(0,1)
+QCFG: “usage/apmem”
+QCFG: “usage/apfs”
+QCFG: “remove_fplmn”,(0,1)
+QCFG: “ftm/mbim”,(0,1)
+QCFG: “ims/ut”,(0,1)
+QCFG: “gpsweek”,(0,1)
+QCFG: “sim/onchip”,(0,1)
+QCFG: “SMS/ListMsgMap”,(“REC UNREAD”,“REC READ”,“STO UNSENT”,“STO SENT”)
+QCFG: “fast/poweroff”,(0,1)
+QCFG: “siminvalirecovery”,(0,1),(1,60),(1,30)
+QCFG: “sleep/datactrl”,(0-7),(50-5000),(0,1)
+QCFG: “sim/type”,(0,1,3)
+QCFG: “epcflag”,(0,1)
+QCFG: “sms/omadm”,(0,1)
+QCFG: “sim/poll_time_delay”,(3-28)
+QCFG: “urc/poweron”,(0,1)
+QCFG: “plmn/autoblock”,(0,1),(1-0xFFFFFFFF)
+QCFG: “fast_dormancy”,(0-3),(1-65535)
+QCFG: “sarcfg”,(“lte_wcdma”,“gsm”),max_power,row_grads,column_grads
+QCFG: “csdctl”,(0,1)
+QCFG: “hplmn/search_timer”,(1-71582)
+QCFG: “Feature_Switch_Flag”,(0,1),(0x01 – 0xFFFFFFFF)
+QCFG: “efratctl”,(0,1)
+QCFG: “w_disable_pin”,(“airplanecontrol”,“pa_gpio”)
+QCFG: “tdd/config”,(0-6),(0-8)
+QCFG: “plmn/addinfbdn”,(0,1)
+QCFG: “icf”,(0-3),(0-3),(0-3)
+QCFG: “mbn/ctcc_compat”,(0,1)
+QCFG: “estk/send_sms”,(0,1)
+QCFG: “dhcppktfltr”,(0,1,2)
+QCFG: “bip/auth”,(0-3)
+QCFG: “ntp”,(1-10),(5- 60)
+QCFG: “ppp/sleep_ri”,(0,1),(500-50000)
+QCFG: “divctl”,(“lte”,“wcdma”),(0-2)
+QCFG: “tcp/windowsize”,(0,1),(16-100)
+QCFG: “rrc/control”,(0,1),(0-60),(0-60),(0-300),(0,1),(0-60)
+QCFG: “iprulectl”,(0,1)
+QCFG: “qoos”,(0-2),(1-600),(1-43200),(1-600),(1-255),(0-60),(0-60),(0-5),(1-60)
+QCFG: “sms_retry”,(0-255),(0-255)
+QCFG: “lte/preferfre”,op,index,band,bandwith,earfcn,mcc,mnc
+QCFG: “urc/smd”,(0-4),(0,1)
+QCFG: “urcport/sms”,(0,1)
+QCFG: “defaultdns”[,[,[,]]]
+QCFG: “vendor”,(0-1)
+QCFG: “call_control”,(0,1),(0,1)
+QCFG: “qti/qmifrag”,(0,1)
+QCFG: “cops_control”,(0,1)
+QCFG: “netmaskset”,(0,1)[,]
i get this list
Is there a document that describes these system configurations and what the parameters are. With the statement that, for example, the value range 0-1 is a possible input, I still don’t know what 0-1 causes/means
best regards
Klaus Ernst
Hi
0 means not effective, 1 means effective, thank you.
This will be of some use…
https://www.quectel.com/wp-content/uploads/2022/06/Quectel_EC2xEG2xEG9xEM05_Series_QCFG_AT_Commands_Manual_V1.0.pdf
Anyone here can figure that out on their own.
What the original thread author is asking: what do these commands do?
Only a few are documented, in the 300+ page manual on the Quectel devices.
E.G. What does AT+QCFG=“usbauto”,1 do?
