We are using the Multitech MTSMC-L4G1 SocketModem which incorporates the Quectel EG25 Revision: EG25GGBR07A08M2G. The modem is communicating fine over the Verizon network in Hurricane, WV USA. We have noticed that the modem always responds with a of 99 when using the AT+CSQ command:
tx>AT+CSQ[D]
rx>[D][A]+CSQ: 22,99[D][A][D][A]OK[D][A]
We are also supporting a customer how wants to use the same modem in our product in Amsterdam Netherlands. They have had experience in the past with other modems returning 99 for and are concerned that this will be a problem. The indicated that using COPS to lock to a certain provider corrected the issue in the past.
What would cause the to always report 99 and do you have any recommendations on this subject?
