Hi all,
I’, trying to test this command AT+CSIM=10,“0070800100”, but I get error. any setting, should be done? Thanks in advance
Is the command supported by this modem? The test syntax AT+CSIM=? will return “OK” if the command is supported.
Is your “0070800100” encoded correctly as per 3GPP 51.011, section 9.
hi, Leila_Ghanbari:
The commamd is not supported by BC95-G.
AT+CLAC //Query all supported AT Command sets
Tanks for your response. AT+CSIM=? returns OK.
execution of AT+CLAC indicate this command is supported
