Hi @Samuel_E
Here are the steps for your reference.
1- Make sure the command is supported in the version you are using.
AT+QETH=“rgmii” // It’s related the Ethernet driver to be loaded
AT+QETH=“eth_at” // Enable/disable sending and receiving AT commands through the Ethernet port
eg.
AT+QETH="eth_driver" //Query the configuration
+QETH: "eth_driver","r8125",0
+QETH: "eth_driver","r8168",1
AT+QETH="eth_driver","r8168",0 //Set the module to not load r8168 when starting.
AT+QETH="eth_at" //Query the configuration
+QETH: "eth_at","enable"
AT+QETH="eth_at","disable" //Disable sending and receiving AT commands through the Ethernet port
2- Make sure your motherboard and PC can ping each other via Ethernet cable, like this.
3- Compile and run the simple(you may need to adjust the code) on the Linux PC in the picture above.
#include <netinet/in.h>
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <fcntl.h>
#include <unistd.h>
#define SERVER_IP "192.168.225.1"
#define SERVER_PORT 1555
#define BUFFER_SIZE 2048*4
int ql_rgmii_manager_server_fd_state(int n)
if(n == -1 && (errno == EAGAIN || errno == EWOULDBLOCK))
return 1;
if( n < 0 && (errno == EINTR || errno == EINPROGRESS))
return 2;
else
return 0;
int main(int argc, char **argv)
char buffer_send[BUFFER_SIZE] = {0};
char buffer_recv[BUFFER_SIZE] = {0};
char buffer_temp[BUFFER_SIZE] = {0};
int rv = 0;
int count = 0;
int len = 0;
int i = 0;
char * datap = NULL;
if(argc == 2)
if(BUFFER_SIZE-3-2 <= strlen(argv[1])) return 0;
memcpy(buffer_send+3, argv[1], strlen(argv[1]));
memcpy(buffer_send+3+strlen(argv[1]), "\r\n", 2);
else if(argc == 1)
snprintf(buffer_send+3, BUFFER_SIZE-3, "at\r\n");
else
return 0;
buffer_send[0] = 0xa4;
buffer_send[1] = (uint8_t)((strlen(buffer_send+3) & (0xff00))>>8);
buffer_send[2] = (uint8_t)(strlen(buffer_send+3) & (0x00ff));
struct sockaddr_in client_addr;
memset(&client_addr, 0, sizeof(client_addr));
client_addr.sin_family = AF_INET;
client_addr.sin_addr.s_addr = htons(INADDR_ANY);
client_addr.sin_port = htons(0);
int client_socket = socket(AF_INET,SOCK_STREAM,0);
if( client_socket < 0)
printf("Create Socket Failed!\r\n");
return 0;
if( bind(client_socket,(struct sockaddr*)&client_addr,sizeof(client_addr)))
printf("Client Bind Port Failed!\r\n");
return 0;
struct sockaddr_in server_addr;
memset(&server_addr, 0, sizeof(server_addr));
server_addr.sin_family = AF_INET;
if(inet_aton(SERVER_IP, &server_addr.sin_addr) == 0)
printf("Server IP Address Error!\r\n");
return 0;
server_addr.sin_port = htons(SERVER_PORT);
socklen_t server_addr_length = sizeof(server_addr);
//set_non_blocking_mode client_socket
fcntl(client_socket, F_SETFL, fcntl(client_socket, F_GETFL, 0) | O_NONBLOCK);
printf("RGMII-AT Client Up => %s:%d\r\n", SERVER_IP, SERVER_PORT);
while(1)
if(connect(client_socket,(struct sockaddr*)&server_addr, server_addr_length) >= 0)
break;
printf("Can Not Connect To => %s:%d\r\n", SERVER_IP, SERVER_PORT);
sleep(2);
if(1)
rv = send(client_socket, buffer_send, (3+(int)strlen(buffer_send+3)),0);
printf("\r\n\r\nsend:\r\n\r\n====================================> send all:%d\r\n==> len=%d head=0x%02x\r\n\"%s\"\r\n",
rv, (int)strlen(buffer_send+3), (uint8_t)buffer_send[0], buffer_send+3);
if(rv != (3+(int)strlen(buffer_send+3)))
printf("Send buf not complete\r\n");
//return 0;
printf("\r\n\r\nrecv:");
while(1)
rv = recv(client_socket, buffer_recv, BUFFER_SIZE, 0);
if(rv >= 3)
printf("\r\n\r\n====================================> recv all:%d", rv);
datap = buffer_recv;
do
len = (((uint16_t)((uint8_t)*(datap+1))<<8) | ((uint16_t)((uint8_t)*(datap+2)) & (0x00ff)));
memset(buffer_temp, 0, sizeof(buffer_temp));
memcpy(buffer_temp, datap+3, len);
printf("\r\n==> len=%d head=0x%02x\r\n\"%s\"\r\n", len, (uint8_t)*(datap), buffer_temp);
for(i=0; i<len; i++)
printf("0x%02x ", buffer_temp[i]);
printf("\r\n");
rv = rv-len-3;
if(rv>0)
datap = buffer_recv+3+len;
if(rv<0)
printf("client_socket recv not complete\r\n");
}while(rv > 0);
memset(buffer_recv, 0, sizeof(buffer_recv));
else if(rv > 0)
printf("client_socket recv error internal\r\n");
break;
else
if(!ql_rgmii_manager_server_fd_state(rv))
printf("client_socket recv error\r\n");
break;
count++;
usleep(10*1000);
if(count == 1000)
break;
printf("\r\n");
close(client_socket);
return 0;
gcc RGMII_AT_Client.c -o RGMII_AT_Client
and run ./RGMII_AT_Client, you will see if everything is fine.
This is the result of my test a long time ago. I am not sure if RG520N can also work. Anyway, you can try it.
