I am trying to read the IMEI off our module but it is not working. I have tried both GSN and CGSN AT commands but neither return anything.
Without the CGSN command everything works correctly with the expected responses but the CGSN command returns nothing (neither OR or ERROR) communication stops.
Below are example logs with the EC25. The response from the EG25 is the same.
Here is a GOOD log:
local2.info chat[8121]: abort on (BUSY)
local2.info chat[8121]: abort on (NO CARRIER)
local2.info chat[8121]: abort on (NO DIALTONE)
local2.info chat[8121]: abort on (ERROR)
local2.info chat[8121]: abort on (NO ANSWER)
local2.info chat[8121]: timeout set to 30 seconds
local2.info chat[8121]: send (AT^M)
local2.info chat[8121]: expect (OK)
local2.info chat[8121]: ^M
local2.info chat[8121]: OK
local2.info chat[8121]: -- got it
local2.info chat[8121]: send (ATE0^M)
local2.info chat[8121]: send (ATI;+CSUB;+CSQ;+COPS?;+CGREG?;&D2^M)
local2.info chat[8121]: Quectel^M
local2.info chat[8121]: EC25^M
local2.info chat[8121]: Revision: EC25EFAR06A04M4G^M
local2.info chat[8121]: SubEdition: V05^M
local2.info chat[8121]: +CSQ: 13,99^M
local2.info chat[8121]: +COPS: 1^M
local2.info chat[8121]: +CGREG: 0,0^M
local2.info chat[8121]: send (AT+CGDCONT=1,"IP","epc.tmobile.com",,0,0^M)
local2.info chat[8121]: send (ATD*99#^M)
local2.info chat[8121]: expect (CONNECT)
local2.info chat[8121]: CONNECT
daemon.debug pppd[5364]: Script chat -s -v -f /etc/chatscripts/sixfab-connect -T epc.tmobile.com finished (pid 8121), status = 0x0
daemon.info pppd[5364]: Serial connection established.
daemon.debug pppd[5364]: using channel 40
daemon.info pppd[5364]: Using interface ppp0
daemon.notice pppd[5364]: Connect: ppp0 <--> /dev/ttyUSB3
daemon.debug pppd[5364]: sent [LCP ConfReq id=0x24 <asyncmap 0x0> <magic 0xa27f3127> <pcomp> <accomp>]
daemon.debug pppd[5364]: rcvd [LCP ConfReq id=0x4e <asyncmap 0x0> <auth chap MD5> <magic 0xd12df876> <pcomp> <accomp>]
daemon.debug pppd[5364]: sent [LCP ConfAck id=0x4e <asyncmap 0x0> <auth chap MD5> <magic 0xd12df876> <pcomp> <accomp>]
daemon.debug pppd[5364]: rcvd [LCP ConfAck id=0x24 <asyncmap 0x0> <magic 0xa27f3127> <pcomp> <accomp>]
daemon.debug pppd[5364]: rcvd [LCP DiscReq id=0x4f magic=0xd12df876]
daemon.debug pppd[5364]: rcvd [CHAP Challenge id=0x1 <043dfabb74a5489d01037e77906861a9>, name = "UMTS_CHAP_SRVR"]
daemon.warn pppd[5364]: No CHAP secret found for authenticating us to 3gppp
daemon.debug pppd[5364]: sent [CHAP Response id=0x1 <4513c728d57e15694f95f138f815a919>, name = ""]
daemon.debug pppd[5364]: rcvd [CHAP Success id=0x1 ""]
daemon.info pppd[5364]: CHAP authentication succeeded
daemon.notice pppd[5364]: CHAP authentication succeeded
daemon.debug pppd[5364]: sent [IPCP ConfReq id=0x24 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
daemon.debug pppd[5364]: sent [IPV6CP ConfReq id=0x24 <addr fe80::d075:7dd4:3ddc:8ac9>]
and here is a BAD log:
local2.info chat[11553]: abort on (BUSY)
local2.info chat[11553]: abort on (NO CARRIER)
local2.info chat[11553]: abort on (NO DIALTONE)
local2.info chat[11553]: abort on (ERROR)
local2.info chat[11553]: abort on (NO ANSWER)
local2.info chat[11553]: timeout set to 30 seconds
local2.info chat[11553]: send (AT^M)
local2.info chat[11553]: expect (OK)
local2.info chat[11553]: ^M
local2.info chat[11553]: OK
local2.info chat[11553]: -- got it
local2.info chat[11553]: send (ATE0^M)
local2.info chat[11553]: send (ATI;+CSUB;+CSQ;+COPS?;+CGREG?;&D2^M)
local2.info chat[11553]: Quectel^M
local2.info chat[11553]: EC25^M
local2.info chat[11553]: Revision: EC25EFAR06A04M4G^M
local2.info chat[11553]: SubEdition: V05^M
local2.info chat[11553]: +CSQ: 13,99^M
local2.info chat[11553]: +COPS: 1^M
local2.info chat[11553]: +CGREG: 0,0^M
local2.info chat[11553]: send (+CGSN=1^M)
