hi i am using mc60
i used this AT+QPCMD and successfully uploaded file but after that i am using “+++”, or any other command nothing is working. i need to restart my mc60 .
so i want to know how to resolve it
i am using AT+QPCMD in call state.i am able to here the audio sent by me in my mobile but after that i am unable to exit
Usually when the three-character sequence +++ is used to transition a modem from data mode to command mode those three “+” characters need to be sent in quick succession with silence either side.
So no <carriage-return> or other termination character after the +++
i am in data mode.
to come from data mode to command mode . i am using +++ but no response in Qcom.
then i tried AT+QPCMD=0,still no response from Qcom.
so what is the right command to exit from data mode in quectel mc60.
You’ve got to suppress the <carriage-return> character used at the end of AT commands.
AT commands need the <carriage-return> to work. The “+++” is not a command, it’s just a three-character string which requires a guard time before and after.
The AT command to switch from data mode to command mode is ATO (that’s the letter “O”). But you’ve got to go through the “+++” mechanism first.
I’m not convinced the ATO command is necessary in this case.
As with all modems from the last 35+ years, you simply put “+++” into the data stream. Not as a command but as a string of three “+” characters, with a couple of seconds “quiet time” before and after.
How are you attempting to introduce “+++” into the data stream? It’s all in the technique.
Why don’t you answer my question about how you’re attempting to send “+++”?
Clear “Send With Enter” checkbox before sending +++ or try another simpler terminal program like putty. It is important to not send any other character or code after the last + within a guard interval.
One of the explanations that could be found on Internet:
When connected and in Data Mode the Escape Sequence will return to Command Mode . The +++Escape Sequence is only recognised if surrounded by a guard interval of 1 second ie. there must be a one second pause before and after entering +++ or it will not be recognised but simply treated as part of the data stream
