In the Quectel_LTE_Standard_Error_Code_List_V1.0_Preliminary.pdf document the AT+CEER command is defined which returns the latest error state from among other things the last network registration failure.
The AT+CEER command does not seem to be implemented on the BG95-M3. Is this the case?
If so, is there an equivalent way of retrieving the same error information from the BG95-M3 using other commands?
