daz@daz:~/Downloads$ adb logcat -b radio -v time
01-01 20:30:12.807 D/RILD ( 605): **RIL Daemon Started**
01-01 20:30:12.807 D/RILD ( 605): **RILd param count=3**
01-01 20:30:13.072 D/RILD ( 605): RIL_Init argc = 3 clientId = 0
01-01 20:30:13.072 D/use-Rlog/RLOG-RIL RILC( 605): Quectel RIL Version: Quectel_Android_RIL_Driver_V2.9.6
01-01 20:30:13.072 D/use-Rlog/RLOG-RIL RILC( 605): libquectel-ril build info: On branch master Your branch is behind 'origin/master' by 12 commits, and can be fast-forwarded. 2456106f3e94775ab344a2254b6d65816e7c9e32 04/14/20_13:17:15
01-01 20:30:13.072 D/use-Rlog/RLOG-RIL RILC( 605): Compiled date: Apr 14 2020 time: 13:17:19
01-01 20:30:13.072 E/use-Rlog/RLOG-RIL RIL_READ_CONF( 605): '/system/etc/ql-ril.conf' not exist.
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): t-prop_value is 1
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): before_dot is 9
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): [ro.build.version.release]: [9.0]
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): Android Version: 90, RIL_VERSION: 12 / 12
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): [ro.build.description]: [msm8937_64-user 8.1.0 OPM1.171019.019 236 release-keys]
01-01 20:30:13.084 D/use-Rlog/RLOG-RIL RILC( 605): [ro.hardware]: [qcom]
01-01 20:30:13.085 D/use-Rlog/RLOG-RIL RILC( 605): selinux maybe set Enforcing mode, use command getenforce to check
01-01 20:30:13.085 D/use-Rlog/RLOG-RIL RILC( 605): selinux maybe set Enforcing mode, use command "setenforce 0" to disable
01-01 20:30:13.085 I/use-Rlog/RLOG-RIL RILC( 605): clientID = 0
01-01 20:30:13.116 I/use-Rlog/RLOG-RIL RILC( 605): mainLoop Start
01-01 20:30:13.117 E/use-Rlog/RLOG-RIL RILU( 605): cannot find ttyname for AT Port
04-22 02:16:30.912 D/TelephonyManager( 618): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
04-22 02:16:30.912 D/TelephonyManager( 618): /proc/cmdline=
04-22 02:16:34.649 D/TelephonyManager( 619): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
04-22 02:16:34.649 D/TelephonyManager( 619): /proc/cmdline=
04-22 02:16:34.747 E/TelephonyManager( 1166): IMSI error: Subscriber Info is null
04-22 02:16:36.277 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:36.660 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:37.267 W/CarrierConfigManager( 1345): Error getting config for subId -1 ICarrierConfigLoader is null
04-22 02:16:37.301 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:37.356 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:37.427 D/TelephonyRegistry( 1166): systemRunning register for intents
04-22 02:16:37.452 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:37.849 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:37.985 D/TelephonyRegistry( 1166): notifyCellLocationForSubscriber: subId=0 cellLocation=Bundle[{}]
04-22 02:16:38.110 D/TelephonyRegistry( 1166): listen oscl: hasNotifySubscriptionInfoChangedOccurred==false no callback
04-22 02:16:48.001 I/ImsManager( 1580): Creating ImsService
04-22 02:16:48.001 W/MmTelFeatureConnection( 1580): create: binder is null! Slot Id: 0
Yes, the log is the demsg information of RIL. It is better to provide the whole log, then we can check whether there have any issues. Thanks!
That is the entire log
