Hello everyone,
I am working on an OpenWRT project with EC20 module. I am using EC20 module in ECM mode. With default SIM settings, I am able to get the internet connection through EC20.
However, the user should be able to configure following settings:
APN, username, password, WAN IP address (for Fixed IP SIM), Authentication type (None/PAP/CHAP/both), dial string
The SIM type can be 2G/3G/4G.
I had figured out a command sequence to configure these settings:
AT+CFUN=0
AT+QICSGP=1,3,“apn”,“username”,“password”,3
AT+CGDCONT=1,“IPV4V6”,“apn”,“135.152.191.150”,0,0,0,0
AT+CFUN=1
AT+CGACT=1,1
ATD*99#
All the commands get proper responses, and after ATD command it responses back with
CONNECT 150000000
After that it doesn’t accept any commands. I need to type +++, I think it’s exits and responds back with
NO CARRIER. and I am able to send the command again.
Above testing was done on 4G SIM. (The operator is 4G only cellular network. 2G/3G is not supported).
My queries are:
I believe dial-up command ATD*99# is required for 2G/3G networks only, and not 4G. Is this correct?
Is above command sequence correct to have internet connection on 2G/3G/4G networks? do I need to have different command sequences for 2G/3G/4G?
I am assuming that if I have fixed IP SIM from network provider, i need to set PDP address as fixed IP assigned by network provider as shown in above in AT+CGDCONT command. Is that correct?
