Anyway to disable aggregation?
I recently purchased a suncomm cp520 pro with the x65 chip. I was hoping n41+n41 would give me a boost compared to x62(spitz ax) but it does not. It actually gives me significantly worse performance. 600Mbps vs 150Mbps download and 145Mbps vs 5Mbps upload. Wanted this outdoor unit so i could mount outside and not have an antenna sitting in my window. So is there anyway to disable it from getting a scc band?
This unit is also pretty hot to the touch, not sure if that is normal since the metal case is supposed to act like a heatsink. My eero did do 1 speed test of 891Mbps but never since and i’ve tried auto apn, manual, nsa and sa. Not sure what setup got that 1 speedtest.
hello, could you tell us the quectel module type and firmware version? thank you~
printed on the module is rm521fglea-m20-sgasa
at+qgmr sends back
RM521FGLEAR05A02M4G_01.200.01.200
@User-Experience-Q or @silvia can support this issue, thanks~
Have you solved the problem? Hello
Lock it to a specific cell (PCI + EARFCN). This combination must be unique to a specific cell in the modem’s current environment.
