It says
+QCFG: "ethernet",1
It says
+QCFG: "ethernet",1
this explains a lot )
Please try
AT+QCFG="ethernet",0
AT+QCFG="usbnet",1
AT+QCFG="nat",2
at+qnetdevctl=1,1,1
AT^RESET
Then check with AT+QNETDEVSTATUS and try DHCP (with the proper interface name).
Please do not use pictures to display textual information.
OMG! Finally, it got a DHCP response. It still can’t ping anything on the internet tho.
pi@ubuntu:~$ ifconfig -a
enxaa1a7249342e: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether aa:1a:72:49:34:2e txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether e4:5f:01:f4:ef:5f txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 101 bytes 8154 (8.1 KB)
TX packets 101 bytes 8154 (8.1 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.43.136 netmask 255.255.255.0 broadcast 192.168.43.255
inet6 fe80::e65f:1ff:fef4:ef61 prefixlen 64 scopeid 0x20<link>
ether e4:5f:01:f4:ef:61 txqueuelen 1000 (Ethernet)
RX packets 151 bytes 19296 (19.2 KB)
TX packets 167 bytes 26489 (26.4 KB)
pi@ubuntu:~$ sudo dhclient -v enxaa1a7249342e
[sudo] password for pi:
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/enxaa1a7249342e/aa:1a:72:49:34:2e
Sending on LPF/enxaa1a7249342e/aa:1a:72:49:34:2e
Sending on Socket/fallback
DHCPDISCOVER on enxaa1a7249342e to 255.255.255.255 port 67 interval 3 (xid=0x5d952477)
DHCPOFFER of 192.168.42.2 from 192.168.42.1
DHCPREQUEST for 192.168.42.2 on enxaa1a7249342e to 255.255.255.255 port 67 (xid=0x7724955d)
DHCPACK of 192.168.42.2 from 192.168.42.1 (xid=0x5d952477)
bound to 192.168.42.2 -- renewal in 33329 seconds.
pi@ubuntu:~$ sudo udhcp -i enxaa1a7249342e
sudo: udhcp: command not found
pi@ubuntu:~$ sudo udhcpc -i enxaa1a7249342e
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: sending select for 192.168.42.2
udhcpc: lease of 192.168.42.2 obtained, lease time 86400
pi@ubuntu:~$ sudo route add -net 0.0.0.0 enxaa1a7249342e
sudo: unable to resolve host ubuntu: Temporary failure in name resolution
pi@ubuntu:~$ ping -I enxaa1a7249342e 8.8.8.8
PING 8.8.8.8 (8.8.8.8) from 192.168.42.2 enxaa1a7249342e: 56(84) bytes of data.
From 192.168.42.2 icmp_seq=1 Destination Host Unreachable
From 192.168.42.2 icmp_seq=2 Destination Host Unreachable
From 192.168.42.2 icmp_seq=3 Destination Host Unreachable
^C
--- 8.8.8.8 ping statistics ---
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5122ms
pipe 3
pi@ubuntu:~$
The AT+CREG and AT+CGREG return 2,0 and the AT+C5GREG returns 0,0.
The AT+CSQ returns 8,99.
Also the interface name keeps changing after each restart anyway to fix that?
Please try with AT+QCFG="nat",0 (followed by reset or re-insert) instead.
Disable arp on the interface with ifconfig or ip utility.
Regarding the interface name problem please see this.
that looks pretty weak to me
Doing this causes the same dhcp can’t get an IP issue.
Maybe this is happening because it’s looking for a 5G network and I am in a 4G coverage area? any way to change that?
Last 0 in each response tells us that the modem is not registered to the network.
Start from the basic troubleshooting - antennas, SIM, bands, etc.
Once you see there 0,1 as before, check with AT+QNETDEVSTATUS and try DHCP again.
The registered status was always 0. I could never register it to a network.
I mean this answer of yours:
If there is no network registration, there is no point in proceeding to the next step(s).
That’s CEREG not CREG or CGREG or C5GREG. Running that still returns 0,1
Well, I’m a bit confused with these AT responses - I’ve checked on my LTE modem (not Quectel though) and I see 0,1 with both +CEREG and +CREG
Do you still have an IP address and correct APN in AT+CGPADDR and AT+CGDCONT? ?
Yes, The ip is different but the rest is same.
AT+CGPADDR
+CGPADDR: 1,"100.74.126.254"
+CGPADDR: 2,""
+CGPADDR: 4,""
+CGPADDR: 11,""
AT+CGDCONT?
+CGDCONT: 1,"IP","UNINET","0.0.0.0",0,0,0,0,,,,,,0,,,0,,0,0,0,0
+CGDCONT: 2,"IPV4V6","","0.0.0.0",0,0,0,2,,,,,,0,,,0,,0,0,0,0
That looks good.
Could you please check if AT+QCFG="nat",1 (followed by reset) will make any difference.
it still shows not registered but CGDCONT has new params,
AT+CGPADDR
+CGPADDR: 1,"100.74.78.226"
+CGPADDR: 2,""
+CGPADDR: 4,""
+CGPADDR: 11,""
AT+CGDCONT?
+CGDCONT: 4,"IP","enxbe94d7918c78","0.0.0.0",0,0,0,0,,,,,,0,,,0,,0,0,0,0
+CGDCONT: 11,"IPV4V6","ims","0.0.0.0",0,0,0,0,,,,,,0,,,0,,0,0,0,0
No it’s all the same outputs. Nothing changed.
Also the AT command AT+QNETDEVSTATUS returns error 4 on this modem.
Try checking with AT+QNETDEVSTATUS=1 instead.
Not sure that is important, but set the same APN that you have in +CGDCONT with AT+QICSGP=1,1,"UNINET"
It shows error 3 now.
Running AT+QICSGP=1,1,“UNINET” didn’t affect the registration status.
@Roney, Did you modify the usb_wwan.c driver for “zero packet”?
No I did not. Can you please guide me through the process?
I thought you mentioned that you followed waveshare instructions ![]()
Under “Add VID and PID” they show how to change the driver(s).
In usb_wwan.c you will see a section added for Quectel’s IDs, search there for “zero packet”.
Translated from Chinese manual:
For the USB Bulk Out transmission mode, if the length of the sent data is an integer multiple of the length of the USB data packet, an additional data packet with a length of zero is used to notify the peer that data transmission is complete.
I am sorry but I don’t see where it says I need to make changes to the file. Also, I tried to follow the windows 10 instructions and it gives me the same results i.e. low signal and no registration. So it might be that the issue is something else?
