I Found this document for LTE power settings, but seems it doesn’t work on EG915U Module!
It uses the commands like:
AT+QNVFW=“/nv/item_files/rfnv/00020994”,0100DC00
to set the TX power.
How can I do same changes in TX power of EG915U Module???
Hi @green_om_2006
The Tx power dynamically adjusts based on network conditions. You are not advised to manually fix the Tx power.
