I am using EC25 Module with IMX8MP Android 14 OS.
I have enabled Radio 1.4 with Quectel Driver Version “Quectel_Android_RIL_Driver_V3.6.24_master_Release” and after board boots i am replacing libril.so with quectel provieded file.
When vendor.ril-daemon tries to start it throws error
“rilc_confi_thread_pool” symbol cannot be found.
I have also tried with Radio V1.0 but Android is Showing No Sim in Mobile Networks Setting So I switched to Radio 1.4.
I have followed Steps provided at https://forums.quectel.com/t/ril-library-not-provided-by-quectel/5178/4?u=himanshusibrain and did driver modifications using User Guide in docs folder.
I have tried using Radio 1.6 too but same error occured, Below are logs for that
09-03 15:01:26.445 1 1 I init : starting service 'exec 2343 (/system/bin/flags_health_check UPDATABLE_CRASHING)'... 09-03 15:01:26.480 1 1 I init : ... started service 'exec 2343 (/system/bin/flags_health_check UPDATABLE_CRASHING)' has pid 22000 09-03 15:01:26.223 22000 22000 I flags_health_check: ServerConfigurableFlagsReset reset_mode value: 1
09-03 15:01:26.223 22000 22000 I flags_health_check: ServerConfigurableFlagsReset updatable crashing detected, resetting flags. 09-03 15:01:26.227 22000 22000 I flags_health_ch: type=1400 audit(0.0:272314): avc: denied { open } for path="/dev/__properties__/u:object_r:device_logging_prop:s0" dev="tmpfs" ino=185 scontext=u:r:flags_health_check:s0 tcontext=u:object_r:device_logging_prop:s0 tclass=file permissive=1
09-03 15:01:26.262 22001 22001 F linker : CANNOT LINK EXECUTABLE "/vendor/bin/hw/rild": cannot locate symbol "rilc_confi_thread_pool" referenced by "/vendor/bin/hw/rild"...
I found problem for “rilc_confi_thread_pool” and resolved it. I did modifications in default rild serivice code and have added this function there. But now as i am using Radio 1.6 i have to replace libril.so and this functions is missing.
Now Another error occurs,
09-03 15:38:16.320 1 1 I init : starting service 'vendor.ril-daemon'... 09-03 15:38:16.352 1 1 I init : ... started service 'vendor.ril-daemon' has pid 4137 --------- beginning of crash 09-03 15:38:16.139 4137 4137 F libc : FORTIFY: memcpy: prevented 994331344-byte write into 32-byte buffer 09-03 15:38:16.139 4137 4137 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4137 (rild), pid 4137 (rild) 09-03 15:38:16.133 4137 4137 I rild : type=1400 audit(0.0:31570): avc: denied { read } for name="ql-ril.conf" dev="dm-0" ino=8044481 scontext=u:r:rild:s0 tcontext=u:object_r:system_file:s0 tclass=fil1 09-03 15:38:16.175 4141 4141 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstoneProto 09-03 15:38:16.178 270 270 I tombstoned: received crash request for pid 4137 09-03 15:38:16.178 4141 4141 I crash_dump64: performing dump of process 4137 (target tid = 4137) 09-03 15:38:16.133 4137 4137 I rild : type=1400 audit(0.0:31571): avc: denied { open } for path="/system/etc/ql-ril.conf" dev="overlay" ino=8044481 scontext=u:r:rild:s0 tcontext=u:object_r:system_fil1 09-03 15:38:16.133 4137 4137 I rild : type=1400 audit(0.0:31572): avc: denied { getattr } for path="/system/etc/ql-ril.conf" dev="overlay" ino=8044481 scontext=u:r:rild:s0 tcontext=u:object_r:system_1 09-03 15:38:16.536 213 213 I logd : logdr: UID=0 GID=1001 PID=4141 n tail=500 logMask=8 pid=4137 start=0ns deadline=0ns 09-03 15:38:16.548 213 213 I logd : logdr: UID=0 GID=1001 PID=4141 n tail=500 logMask=1 pid=4137 start=0ns deadline=0ns 09-03 15:38:16.272 4141 4141 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** 09-03 15:38:16.272 4141 4141 F DEBUG : Build fingerprint: 'Android/verdin_8mp/verdin_8mp:14/UQ1A.231205.015/eng.sibrai.20240820.153117:userdebug/dev-keys' 09-03 15:38:16.272 4141 4141 F DEBUG : Revision: '0' 09-03 15:38:16.272 4141 4141 F DEBUG : ABI: 'arm64' 09-03 15:38:16.272 4141 4141 F DEBUG : Timestamp: 2024-09-03 15:38:16.181762375+0000 09-03 15:38:16.272 257 262 W libperfmgr: Failed to write to node: /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq with value: 1800000, fd: -1 09-03 15:38:16.272 4141 4141 F DEBUG : Process uptime: 2s 09-03 15:38:16.272 4141 4141 F DEBUG : Cmdline: /vendor/bin/hw/rild -l /vendor/lib64/libquectel-ril.so 09-03 15:38:16.272 257 262 W libperfmgr: Failed to write to node: /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq with value: 1200000, fd: -1 09-03 15:38:16.272 4141 4141 F DEBUG : pid: 4137, tid: 4137, name: rild >>> /vendor/bin/hw/rild <<<
09-03 15:38:16.272 4141 4141 F DEBUG : uid: 0
09-03 15:38:16.272 4141 4141 F DEBUG : tagged_addr_ctrl: 0000000000000001 (PR_TAGGED_ADDR_ENABLE)
09-03 15:38:16.272 4141 4141 F DEBUG : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
09-03 15:38:16.272 4141 4141 F DEBUG : Abort message: 'FORTIFY: memcpy: prevented 994331344-byte write into 32-byte buffer' 09-03 15:38:16.272 4141 4141 F DEBUG : x0 0000000000000000 x1 0000000000001029 x2 0000000000000006 x3 0000ffffc4bbb2f0 09-03 15:38:16.272 4141 4141 F DEBUG : x4 32323338381f6364 x5 32323338381f6364 x6 32323338381f6364 x7 7f7f7f7f7f7f7f7f 09-03 15:38:16.273 4141 4141 F DEBUG : x8 00000000000000f0 x9 0000f5b749460090 x10 0000000000000001 x11 0000f5b7494b6f00 09-03 15:38:16.273 4141 4141 F DEBUG : x12 0000000066d72d68 x13 000000007fffffff x14 0000000000035e7c x15 000000011e3ab252 09-03 15:38:16.273 4141 4141 F DEBUG : x16 0000f5b749530d08 x17 0000f5b7494ff810 x18 0000f5b753ebe000 x19 00000000000000ac 09-03 15:38:16.273 4141 4141 F DEBUG : x20 00000000000000b2 x21 0000000000001029 x22 0000000000001029 x23 00000000ffffffff 09-03 15:38:16.273 4141 4141 F DEBUG : x24 0000ffffc4bbb590 x25 0000000000000000 x26 0000000000000000 x27 0000000000000002 09-03 15:38:16.273 4141 4141 F DEBUG : x28 0000c50499f40348 x29 0000ffffc4bbb370
09-03 15:38:16.273 4141 4141 F DEBUG : lr 0000f5b7494a7414 sp 0000ffffc4bbb2d0 pc 0000f5b7494a7444 pst 0000000000000000 09-03 15:38:16.273 4141 4141 F DEBUG : 8 total frames
09-03 15:38:16.273 4141 4141 F DEBUG : backtrace:
09-03 15:38:16.273 4141 4141 F DEBUG : #00 pc 0000000000069444 /apex/com.android.runtime/lib64/bionic/libc.so (abort+180) (BuildId: 218db69eb66aeb253a34d956906a8bba) 09-03 15:38:16.273 4141 4141 F DEBUG : #01 pc 000000000006b39c /apex/com.android.runtime/lib64/bionic/libc.so (__fortify_fatal(char const*, ...)+124) (BuildId: 218db69eb66aeb253a34d956906a8bba) 09-03 15:38:16.273 4141 4141 F DEBUG : #02 pc 0000000000096f18 /apex/com.android.runtime/lib64/bionic/libc.so (__check_buffer_access(char const*, char const*, unsigned long, unsigned long)+40) (Bu) 09-03 15:38:16.273 4141 4141 F DEBUG : #03 pc 00000000000970c4 /apex/com.android.runtime/lib64/bionic/libc.so (__memcpy_chk_fail+68) (BuildId: 218db69eb66aeb253a34d956906a8bba) 09-03 15:38:16.274 4141 4141 F DEBUG : #04 pc 00000000000980a0 /apex/com.android.runtime/lib64/bionic/libc.so (__memcpy_chk+16) (BuildId: 218db69eb66aeb253a34d956906a8bba) 09-03 15:38:16.274 4141 4141 F DEBUG : #05 pc 000000000003dea8 /vendor/lib64/libquectel-ril.so (RIL_Init+1196) (BuildId: 4c5946f37cb74d34f80cf17d8fe151f6) 09-03 15:38:16.274 4141 4141 F DEBUG : #06 pc 0000000000010364 /vendor/bin/hw/rild (main+756) (BuildId: 0a851a665bab285f5a404649ddc338f8) 09-03 15:38:16.274 4141 4141 F DEBUG : #07 pc 0000000000061838 /apex/com.android.runtime/lib64/bionic/libc.so (__libc_init+104) (BuildId: 218db69eb66aeb253a34d956906a8bba) --------- beginning of system
09-03 15:38:16.287 607 834 W NativeCrashListener: Couldn't find ProcessRecord for pid 4137
09-03 15:38:16.288 270 270 E tombstoned: Tombstone written to: tombstone_11
09-03 15:38:16.289 607 687 E NativeTombstoneManager: Tombstone's UID (0) not an app, ignoring
09-03 15:38:16.290 607 687 E NativeTombstoneManager: Tombstone's UID (0) not an app, ignoring
09-03 15:38:16.582 1 1 I init : Untracked pid 4141 exited with status 0
09-03 15:38:16.591 1 1 I init : Untracked pid 4141 did not have an associated service entry and will not be reaped 09-03 15:38:16.603 1 1 I init : Service 'vendor.ril-daemon' (pid 4137) received signal 6
09-03 15:38:16.614 1 1 I init : Sending signal 9 to service 'vendor.ril-daemon' (pid 4137) process group... 09-03 15:38:16.626 1 1 I libprocessgroup: Successfully killed process cgroup uid 0 pid 4137 in 0ms
I think you can try the IRadio 1.5 first.
If it still not work let’s try AIDL later.
Please provide the log files.
Hi @Bean.Wang-Q
Sorry for Delayed Response.
I finally got working.
I have implemented Audio Routing Logic, too. If you have any lead for that please share.
Sounds great!
The EC25 support UAC and Voice over USB, I don’t know how the audio works with only the MIC and speaker on the Android.This is something that Android audio experts will be familiar with. I would be happy if you could give me a brief introduction.
@Bean.Wang-Q Thanks for Your Support Over Time.
I am not allowed to share more information as It is IP of our company.
That’s Great. I’m still glad you figured it out. At least I haven’t had any customers say they figured out Android audio routing with the UAC before.
Yeah.
I will share Video Link for the Demo when Its uploaded on LinkedIn.
@Bean.Wang-Q In AOSP settings app, manual network selection doesn’t display available networks. Calls and SMS function properly even on serial i get list of network using cops command.
Any logs, could you show it with pictures?
@Bean.Wang-Q yes i have mention log below.
E PhoneInterfaceManager: [PhoneIntfMgr] getForbiddenPlmns() no app with specified type – 2
D NetworkScanHelper: Network scan status: 1
D NetworkScanHelper: Available operators: null
in the ql-ril.conf make sure
Query_Available_Networks=1
@Bean.Wang-Q yes it is Query_Available_Networks=1.but unable to get list of manual network.
Disabling automatic network search resulted in only one network being available; others are not detected.
I have attached the relevant log files for your review.
log.txt (4.1 KB)
Just from the log, it seems that it do not support the AT command AT+QCSAN.
05-16 16:59:51.180 2133 2134 D CELL_INFO: qcomm_qscan:1580 g_is_scan_ing = 1
05-16 16:59:51.180 2133 2134 D ATC : AT> AT+QSCAN=2,1
05-16 16:59:51.180 1021 1159 D RILJ : [5381]< START_NETWORK_SCAN {scanStatus=1, scanError=0, networkInfos=null} [PHONE0]
05-16 16:59:51.187 2133 2137 D ATC : AT< ERROR 05-16 16:59:51.187 2133 2134 D CELL_INFO: qcomm_qscan_nr:1570 size = 0
05-16 16:59:51.187 2133 2134 D ATC : AT> AT+QSCAN=1,1
05-16 16:59:51.192 2133 2137 D ATC : AT< ERROR
Thank you for the update @Bean.Wang-Q . In that case, could you please advise how we can resolve this issue? Also, could you please provide the firmware that supports the AT+QCSAN command?
Normally it should use the AT+COPS=2 to querry the available network.
What’s the module it is?
@Bean.Wang-Q We are utilizing the libril.so and libreference-ril.so files on the EC25 GSM module.
It should not use the AT+QCAN. Where did you find the libs? Is the cellular working except the available network?
@Bean.Wang-Q, The cellular functionality—including voice calls, SMS, and internet—works correctly on our device. We referenced the RIL library from the Quectel forum for integration. If this library is not suitable for Android 13 (AOSP 13) on the EC25 module, could you please provide the appropriate RIL library for this configuration?
