Please help me upgrade my AQ550Q-CN
My modem does not see the network of the Kyrgyz operator, will it help to flash the modem?
Sotovik996@gmail.com
+996777192727 WhatsApp
What seems to be the problem? SIM card related? or Network environment?
Can you provide the related logs and details of operation that you have tried?
BR,
Louis
I found out that the network is working but there is no Internet, do you think it will help if you register the APN through the AT command?
Please make sure the cellular antenna is installed properly, after that, send the following command and share the result.
at+cpin?;creg?;+cereg?;+C5GREG?;+cops?;+csq;+qnwinfo;+CGACT?
BR,
Louis
I was able to enter my login and password, please tell me how to enter AT commands. please
You can enter “ql_cmd at at+cpin?” for executing “at+cpin?”, others likewise.
BR,
Louis
~ # ql_cmd at at+cpin?
+CPIN: READY
~ # ql_cmd at at+creg?
+CREG: 0,1
~ # ql_cmd at at+cereg?
+CEREG: 0,1
~ # ql_cmd at at+C5GREG?
+C5GREG: 0,0
~ # ql_cmd at at+cops?
+COPS: 0,0,“beeline Beeline”,7
~ # ql_cmd at at+csq
+csq: 22,99
~ # ql_cmd at at+CGACT?
+CGACT: 1,1+CGACT: 2,0
+CGACT: 3,0+CGACT: 38,0
+CGACT: 39,0+CGACT: 5,0
+CGACT: 6,1
+CGACT: 7,1+CGACT: 8,1
~ # ql_cmd at at+qnwinfo
+QNWINFO: “FDD LTE”,“25099”,“LTE BAND 7”,3300
write is it possible to add APN? thank you
You now have the CID=1/6/7/8 channels activated, I believe the network function is working now.
You can use the following command for editting APN.
ql_cmd at at+cgdcont=2,“IPV4V6”,“edit-apn-here”
Then enter at+CGACT=2,1 to activate the channel 2.
BR,
Louis
That is not “the network of the Kyrgyz operator” as stated in the initial post.
thank you very much, you are the best
Hello mr Louis
~ # ql_cmd at at+cgdcont=2,“IPV4V6”,“internet.beeline.kg”
ERROR
icant add my apn
Is it possible that our countries Russia and Kyrgyzstan are blocked in this version of the firmware?
If so, is it possible to upgrade to a different firmware version?
They don’t bother with proper formatting. Copy/paste the command from below:
at+cgdcont=2,"IP","internet.beeline.kg"
Check what you have configured with at+cgdcont? Please format the output using </> button.
You may need to deactivate the APN or disable radio before making changes.
hello dears. how to deactivate APN? I’m new to this but I’m learning quickly
Can you please tell me where I can ask for the stock firmware?
Please show the result of at+cgdcont? before making changes.
