AG215S module user guide / login information
I have an 5G+CV2X evaluation board. This setup has following components.
AG550Q, AG215, AF50T and Ethernet
Can anyone provide the user guide for AG215S-CN module. I am trying to login to system using DBG UART without much luck.
See ‘systemctl status init_audio.service’ for details.
[ OK ] Stopped Audio Init Service.
Starting Audio Init Service…
[ OK ] Started Audio Init Service.
[ OK ] Started diagrebootapp service.
[ OK ] Started powermanager-daemon Service.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started ethpwrmgr service.
[ OK ] Found device /dev/ttyMSM0.
[ OK ] Started Serial Getty on ttyMSM0.
[ OK ] Reached target Login Prompts.
auto 1647 sa515m ttyMSM0
sa515m login:
Any help?
sa515m login: root
Password:oelinux123
did you connect via putty? for some reason I can’t print a command, help me solve it
EFI Start [ 1277]
  • 0x08F701000 [ 1293] Sec.efi
    PROD Mode : On
    ASLR : On
    Timer Delta : +17 mS
    RAM Entry 0 : Base 0x0000000080000000 Size 0x0000000020000000
    RAM Entry 1 : Base 0x00000000A0000000 Size 0x000000001FF80000
    Could not find the DBI Dump region .
    UEFI Ver : 5.0.210616.BOOT.UEFI.4.0-00200-SDX55LEZB-2
    Build Info : 32b Jun 16 2021 02:20:05
    Boot Device : NAND
    DEP Enabled
    PM3: 33, PM4: 42,
    UsbConfigPortsQueryConnectionChange: Failed to get UsbCGetPortState, falling bac k to UNKNOWN platform
    @AB@ get fotainfo from rawdata, activeslot = 0
    @AB@ boot abl part
Platform Init [ 1601] BDS
Platform : TTP
Subtype : 0
Chip Name : SA515M
Chip Ver : 2.0
Core 0 Freq: 1497 MHz
UEFI Total : 325 ms
POST Time [ 1602] OS Loader
Loader Build Info: Jan 1 2022 07:36:49
VB: RWDeviceState: Succeed using devinfo!
Input Open protocol failed Status:Not Ready
BootMode:0, BootReason:0
Fastboot=0, Recovery:0
GetVmData: making ScmCall to get HypInfo
GetVmData: No Vm data present! Status = (0x80000003)
VM Hyp calls not present
Booting Into Mission Mode
Loading Image Start : 1771 ms
Loading Image Done : 1777 ms
Total Image Read size : 4096 Bytes
Loading Image Start : 1777 ms
Loading Image Done : 2605 ms
Total Image Read size : 13930496 Bytes
No dtbo partition is found, Skip dtbo
VB: verification skipped for debug builds
@AB@Load modem from modem, ModemMtd=38
@AB@Load system from system, SystemMtd=39
@AB@ Load kernel from boot
No Ffbm cookie found, ignore: Not Found
get image from:boot,BootPart=bo
Memory Base Address: 0x80000000
BootLinux: failed to get dtbo image
DTB offset is incorrect, kernel image does not have appended DTB
Failed to get Boot Device Base address, Buffer Too Small
Failed to get Boot Device: Buffer Too Small
Unable to get Panel Config, Not Found
Loading Image Start : 2711 ms
Loading Image Done : 2712 ms
Invalid char for early ipv4 0xAF at 0
USB Composition Magic Verification Failed
Cmdline: dm-verity ro console=ttyMSM0,115200,n8 androidboot.hardware=qcom msm_rt b.filter=0x237 androidboot.console=ttyMSM0 lpm_levels.sleep_disabled=1 firmware_ class.path=/lib/firmware/updates service_locator.enable=1 net.ifnames=0 rootfsty pe=squashfs roo
RAM Partitions
Add Base: 0x0000000080000000 Available Length: 0x0000000020000000
Add Base: 0x00000000A0000000 Available Length: 0x000000001FF80000
Failed to get MinPasrSize, Status = Unsupported
Unable to get splash buffer info, Not Found
kaslr-Seed is added to chosen node
Shutting Down UEFI Boot Services: 2748 ms
BDS: LogFs sync skipped, No Media
App Log Flush : 85 ms
Exit BS [2836] UEFI End
[RamDisk] Ram rootfs is running …
[RamDisk] Ram rootfs is done …
Welcome to auto 202201011500!
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Swap.
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on Journal Socket.
Starting Apply Kernel Variables…
Starting chgrp-diag Service…
Starting Load/Save Random Seed…
Starting Journal Service…
Starting Mount firmware partition to /firmware mount point…
[ OK ] Started SSREQ server Service.
[ OK ] Listening on initctl Compatibility Named Pipe.
Mounting POSIX Message Queue File System…
[ OK ] Listening on udev Control Socket.
Starting Modem Init Service…
[ OK ] Reached target Timers.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started chgrp-diag Service.
[ OK ] Started Modem Init Service.
Starting init-can Service…
Starting Load evdev kernel module…
Starting Qseecomd Service…
[ OK ] Started init-can Service.
[ OK ] Started Qseecomd Service.
[ OK ] Started Load evdev kernel module.
[ OK ] Started Flush Journal to Persistent Storage.
Starting label-data…
[ OK ] Started qrtr-ns Service.
Mounting Kernel Configuration File System…
Mounting Kernel Debug File System…
Starting QCMAP_copybind service…
[ OK ] Started irsc-util Service.
Starting IPA FW Service…
Starting Netmgrd Service…
Starting label-persist…
[ OK ] Started Qwes License Store Service.
[ OK ] Started Qwesd Service.
Starting GPS Location process launcher…
[ OK ] Started Mount firmware partition to /firmware mount point.
[FAILED] Failed to start label-data.
See ‘systemctl status label-data.service’ for details.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Netmgrd Service.
[FAILED] Failed to start label-persist.
See ‘systemctl status label-persist.service’ for details.
[ OK ] Started GPS Location process launcher.
Starting location remote service launcher…
[ OK ] Started Staring tftp server.
[ OK ] Started IPA FW Service.
[ OK ] Started QCMAP_copybind service.
Starting usb Service…
[ OK ] Started usb Service.
Starting adbd Service…
[ OK ] Started adbd Service.
Mounting Temporary Directory (/tmp)…
Starting Create Static Device Nodes in /dev…
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile…
Mounting /cache…
Starting udev Kernel Device Manager…
[ OK ] Mounted /var/volatile.
[FAILED] Failed to mount /cache.
See ‘systemctl status cache.mount’ for details.
[DEPEND] Dependency failed for label-cache.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
[ OK ] Started Create Volatile Files and Directories.
Starting Logd logging Service…
Starting IPACM Service…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started D-Bus System Message Bus.
Starting qti service…
[ OK ] Started qti service.
[ OK ] Started Logd logging Service.
[ OK ] Found device /dev/input/event0.
[ OK ] Started Monitor /dev/socket path to start logd.
[ OK ] Reached target Paths.
Starting logd logging service…
[ OK ] Started logd logging service.
[ OK ] Started IPACM Service.
[ OK ] Started location remote service launcher.
Starting udev Coldplug all Devices…
[ OK ] Reached target Sockets.
Starting Bind mount volatile /etc/data/iproute2/rt_tables…
Starting Bind mount volatile /etc/misc/wifi/…
Starting Bind mount volatile /etc/data/usb/…
Starting Bind mount volatile /etc/data/…
Starting Bind mount volatile /etc/data/ipa/…
Starting Bind mount volatile /etc/usb/boot_hsic_comp…
Starting Bind mount volatile /etc/data/adpl/…
[ OK ] Started Bind mount volatile /etc/data/usb/.
[ OK ] Started Bind mount volatile /etc/data/iproute2/rt_tables.
[ OK ] Started Bind mount volatile /etc/misc/wifi/.
[ OK ] Started Bind mount volatile /etc/data/ipa/.
[ OK ] Started Bind mount volatile /etc/usb/boot_hsic_comp.
[ OK ] Started Bind mount volatile /etc/data/adpl/.
[ OK ] Started Bind mount volatile /etc/data/.
[ OK ] Reached target Basic System.
[ OK ] Started Getty on tty1.
[ OK ] Started qti_ppp service.
[ OK ] Started QTI Mobile Broadband Service.
[ OK ] Started IPACM Perf Service.
[ OK ] Started Crypto modules installation service.
Starting System Logging Service…
[ OK ] Started Qmuxbridge Service.
[ OK ] Started QUECTEL WiFi Services.
Starting Login Service…
[ OK ] Started Modem Shutdown Service.
[ OK ] Started Setup avtp routing service.
Starting Bluetooth Power Service…
Starting Thermal Engine Service…
[ OK ] Started Quectel time daemon Service.
[ OK ] Started Quectel EAVB Config Service.
[ OK ] Started Reset reboot cookie.
Starting NTP client/server…
[ OK ] Started adpl service.
Starting Port bridge Service…
[ OK ] Started Setting the power config.
[ OK ] Started reboot-daemon service.
[ OK ] Started pdmapper Service.
Starting diagrebootapp service…
[ OK ] Started Quectel Factory AT Handler Service.
[ OK ] Started QUECTEL MANAGEMENT Services.
[ OK ] Started set_core_pattern Service.
Starting powermanager-daemon Service…
Starting MODPROBE_CNSS2_MODULE…
[ OK ] Started Quectel QDR Can Simulator.
[ OK ] Started data-init service.
[ OK ] Started QUECTEL NET Services.
[ OK ] Started sfs configuration Service.
Starting Post modem boot service…
[ OK ] Started System Logging Service.
[ OK ] Started Bluetooth Power Service.
[ OK ] Started NTP client/server.
[ OK ] Started Port bridge Service.
[ OK ] Started MODPROBE_CNSS2_MODULE.
[FAILED] Failed to start Audio Init Service.
[ OK ] Started Thermal Engine Service.
[ OK ] Started Login Service.
[ OK ] Started Audio DLKM kernel service.
auto 1517 sa515m ttyMSM0
sa515m login: root
No reaction
