Adjust update rate of NMEA output sentences for EM06-E LTE Cat-6 HAT
We have an EM06-E LTE Cat-6 HAT. As in “EM06 Series Hardware Design” document, page 42, it said that: The module supports standard NMEA-0183 protocol, and outputs NMEA sentences at 1 Hz data update rate via USB interface by default.
Can we adjust update rate to be greater than 1 Hz. If so, how to we set that argument through AT command?
If we cannot adjust that argument, can we solve it in another way?
Please check whether it support the AT command
AT+QGPSCFG="fixfreq"
If this instruction is not supported, there is nothing we can do.
