About URC: +QIND: "ccinfo"
Hi
I need documentations about URC (AT+QINDCFG=“ccinfo”,1):
+QIND: "ccinfo",<id>,<dir>,<state>,<mode>,<mpty>,<number>,<type>[,<alpha>]
In the AT Command Manual V2.0 there isen’t… Can you Help me?
My module is:
EC25 EUX
Revision: EC25EUXGAR08A08M1G
Hi Tommy
You can refer to the document, thank you
Quectel_EC200U&EG915U_Series_AT_Commands_Manual_V1.0.pdf (1.2 MB)
I need URC documentation:
Please refer to the chapter in the attached document
7.18 List current calls +CLCC
27007-h10.zip (1.0 MB)
Thanks for the help Herbert.
I tested +QIND: "ccinfo" and I saw < state > = -1 when close incoming call.
< state > = -1 is not present in CLCC command. I think is an exception because the call is not present.
There are other exceptions in the +QIND: "ccinfo" parameters?
Please upload your query results
RING
^DSCI: 4,1,4,0,xxxxxxxx,145
+QIND: “ccinfo”,4,1,4,0,0,“xxxxxxxx”,145
AT+CLCC
+CLCC: 1,1,0,1,0,"",128
+CLCC: 2,1,0,1,0,"",128
+CLCC: 4,1,4,0,0,“xxxxxxxx”,145
+CLCC: 3,1,0,1,0,"",128
RING
AT+CLCC
^DSCI: 4,1,6,0,xxxxxxxx,145
+QIND: “ccinfo”,4,1,-1,0,0,“xxxxxxxx”,145
NO CARRIER
AT+CLCC
I think I’ll use the ^DSCI. It is more documented in my opinion.
What do you think?
yes,you can,Anything that achieves your purpose is a good way to do it
