Topics related to Quectel WiFi/BT modules for short distance transmission in following categories.
Im trying to connect my FCM360W module to Wifi, for which im referring Quectel mannual for AT commands my module is able to scan the available wifi network and even if the desired network is found it is not able to connect to the same network using SSID and password following are the AT commands im trying to use AT+QCFG="usbnet",1 , AT+QWSCAN , AT+QWSTA=0, AT+QWSTA="$WIFI_SSID","$WIFI_PASSWORD", AT+QSTASTAT , AT+QGETIP, and this is the output im getting OK
Found desired Wi-Fi network: WHLB-Guest.
Setting module to STA mode…
ERROR
Setting module to STA mode and connecting to Wi-Fi…
Connection Response:
ERROR
Wi-Fi State:
ERROR
Connection Status:
ERROR
Failed to connect to Wi-Fi. Exiting.
you can refer to the example of AT commands,the desired wifi ssid is “ezioM” and the password is 12345678
AT+QECHO=1
AT+QWSCAN
+QWSCAN:“sxf-2.4G”,“wpa/wpa2”,-86,“703a73055024”,11
+QWSCAN:“sxf-szdevice”,“wpa/wpa2”,-85,“703a73155024”,11
+QWSCAN:“淇℃湇璁垮”,“open”,-84,“703a730d5024”,11
+QWSCAN:“Quectel-SZ”,“wpa/wpa2”,-76,“78cf2f91c612”,11
+QWSCAN:“Visitor-Quectel”,“wpa/wpa2”,-76,“78cf2f91c611”,11
+QWSCAN:“quectel”,“wpa/wpa2”,-77,“78cf2f91c610”,11
+QWSCAN:“”,“wpa/wpa2”,-90,“12823dd33eff”,6
+QWSCAN:“閫告櫙鑼楃紭”,“wpa2”,-88,“12823df33f1b”,6
+QWSCAN:“WLAN_1fc775_2G”,“open”,-72,“0ec1191dc775”,8
+QWSCAN:“閫告櫙鑼楃紭”,“wpa2”,-92,“12823df33eff”,6
+QWSCAN:“sxf-2.4G”,“wpa/wpa2”,-81,“a80cca03483e”,6
+QWSCAN:“sxf-szdevice”,“wpa/wpa2”,-81,“a80cca13483e”,6
+QWSCAN:“winforce”,“wpa2”,-75,“a0107709da52”,6
+QWSCAN:“淇℃湇璁垮”,“open”,-82,“a80cca0b483e”,6
+QWSCAN:“Quectel-SZ”,“wpa/wpa2”,-85,“78cf2f91ae12”,6
+QWSCAN:“Visitor-Quectel”,“wpa/wpa2”,-84,“78cf2f91ae11”,6
+QWSCAN:“quectel”,“wpa/wpa2”,-85,“78cf2f91ae10”,6
+QWSCAN:“DIRECT-96-HP 4104dw LJ”,“wpa2”,-91,“32138b05fc96”,6
+QWSCAN:“ezioM”,“wpa2”,-50,“46a3bb86fad8”,6
+QWSCAN:“alan”,“wpa2”,-82,“12f60a429cbc”,6
+QWSCAN:“淇℃湇璁垮”,“open”,-90,“a80cca0b29f6”,1
+QWSCAN:“Visitor-Quectel”,“wpa/wpa2”,-88,“78cf2f91c771”,1
+QWSCAN:“quectel”,“wpa/wpa2”,-88,“78cf2f91c770”,1
+QWSCAN:“TP-LINK_2.4G_29FF”,“open”,-69,“743989e029ff”,1
AT+QSTAAPINFO=“ezioM”,“12345678”
+QSTASTAT: “WLAN_CONNECTED”
+QSTASTAT: “GOT_IP”
