Hi Quectel, I’m using to ec25 and use HTTPGET to get an audio file (mp3) from the server, and i connect the module with audio codec like this in order to play with a speaker, but i have some questions:
After httpget from the server, will the audio file be saved in the module, if it does, how can i play it, and delete it by using at command?
Hi @Linh_Ph_m
Will be stored in the module, you can check and select audio files through the FILE guide.
