A-GNSS MSB with TLS on EG25-G
I’m struggling with TLS on supl.google.com.
$ mmcli -m any --command='AT+QGPSCFG="plane"'
response: '+QGPSCFG: "plane",1'
$ mmcli -m any --command='AT+QGPSSUPLURL?'
response: '+QGPSSUPLURL: "supl.google.com:7275"'
$ mmcli -m any --command='AT+QGPS=2'
response: ''
$ mmcli -m any --command='AT+QGPSGNMEA="GSV"'
response: ''
response: ''
response: ''
I’ve tried to upload https://secure.globalsign.net/cacert/Root-R1.crt to the modem and import it using following command. Is it the right certificate to upload?
$ mmcli -m any --command='AT+QGPSSUPLCA="RAM:Root-R1.crt"'
response: ''
Unfortunately nothing has changed. I still don’t see any GSV messages in the output.
if SUPL is configured without TLS (supl.google.com:7276 and plane,0), then everything works and I get
response: '+QGPSGNMEA: $GPGSV,4,1,13,05,01,037,,07,12,322,,08,22,296,,10,28,187,,1*64
+QGPSGNMEA: $GPGSV,4,2,13,13,19,039,,15,27,073,,16,41,229,,18,51,084,,1*6F
+QGPSGNMEA: $GPGSV,4,3,13,23,57,146,,26,17,205,,27,54,281,,29,,,,1*50
+QGPSGNMEA: $GPGSV,4,4,13,30,09,352,,1*58'
What do I need to get SUPL working with supl.google.com:7275?
I setup supl proxy to check, whether modem connects to the server.
I see modem tries to establish TLSv1.1 (it’s an old and deprecated protocol, that modern servers don’t support anymore) and modem closes connection after receiving ‘Certificate’ by sending ‘Close Notify’ alert.
  1. Is only TLSv1.1 supported?
  2. Why modem closes connection?
@lyman-Q Is it possible to use SSL (7275) with supl.google.com?
It supports TLS 1.2; I suggest you export all the AT logs.
I wrote simple python script for testing SUPL.
load_supl_ssl_test.py (2.1 KB)
Here is test without SSL. You see that there are non-empty GSV messages after start.
$ sudo python3 load_supl_ssl_test.py
open serial port
Check modem talk to us
AT
[b'\r\n', b'OK\r\n']
AT+QGPSEND
[b'\r\n', b'+CME ERROR: 505\r\n']
AT+QGPSXTRA=0
AT+QGPSDEL=3
AT+QGPSDEL=0
AT+QGPSXTRADATA?
[b'\r\n', b'+CME ERROR: 509\r\n']
AT+QFDEL="RAM:data.bin"
upload file to the modem
AT+QFUPL="RAM:data.bin",889
[b'\r\n', b'CONNECT\r\n']
[b'+QFUPL: 889,6b94\r\n', b'\r\n', b'OK\r\n']
set supl ca to file we uploaded
AT+QGPSSUPLCA="RAM:data.bin"
write configuration
AT+QGPSCFG="plane",0
AT+QGPSSUPLURL="supl.google.com:7276"
read configuration
AT+QGPSCFG="suplver"
[b'\r\n', b'+QGPSCFG: "suplver",2\r\n', b'\r\n', b'OK\r\n']
AT+QGPSCFG="plane"
[b'\r\n', b'+QGPSCFG: "plane",0\r\n', b'\r\n', b'OK\r\n']
AT+QGPSSUPLURL?
[b'\r\n', b'+QGPSSUPLURL: "supl.google.com:7276"\r\n', b'\r\n', b'OK\r\n']
start GNSS receiver (MSB)
AT+QGPS=2
AT+QGPSGNMEA="GSV"
[b'\r\n', b'+QGPSGNMEA: $GPGSV,3,1,12,01,00,007,,03,09,026,,06,31,104,,11,13,140,,1*6B\r\n', b'+QGPSGNMEA: $GPGSV,3,2,12,12,62,253,,17,21,052,,19,45,067,,22,08,087,,1*68\r\n', b'+QGPSGNMEA: $GPGSV,3,3,12,24,49,181,,25,30,265,,28,01,313,,32,29,302,,1*60\r\n', b'\r\n', b'OK\r\n']
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
stop GNSS receiver
AT+QGPSEND
AT+QGPSDEL=3
AT+QGPSDEL=0
close serial port
Here is test without SSL. GSV messages are empty.
$ sudo python3 load_supl_ssl_test.py --ssl
open serial port
AT
AT+QGPSEND
AT+QGPSXTRA=0
AT+QGPSDEL=3
AT+QGPSDEL=0
AT+QGPSXTRADATA?
write configuration
AT+QGPSCFG="plane",1
AT+QGPSSUPLURL="supl.google.com:7275"
read configuration
AT+QGPSCFG="plane"
[b'\r\n', b'+QGPSCFG: "plane",1\r\n', b'\r\n', b'OK\r\n']
AT+QGPSSUPLURL?
[b'\r\n', b'+QGPSSUPLURL: "supl.google.com:7275"\r\n', b'\r\n', b'OK\r\n']
AT+QGPS=2
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
AT+QGPSGNMEA="GSV"
stop GNSS receiver
AT+QGPSEND
AT+QGPSDEL=3
AT+QGPSDEL=0
close serial port
This file is used for uploading as SUPL CA http://secure.globalsign.com/cacert/root-r1.crt
Is it the correct one?
@herbert.pan-Q any hints, what could be wrong here?
When I setup my own server for debugging, I see only TLS 1.1 connection attempts in wireshark.
Please provide the version of your current firmware.
AT+QGMR
EG25GGBR07A08M2G_30.007.30.007
I’ve looked at release notes of A0.300.A0.300 and couldn’t find anything related to this problem in the changelog.
I’ve tested TLSv1.2 support in firmware using AT+QSSL* commands and could successfully establish connection to my test server and supl.google.com. I see with wireshark, that connection uses TLSv1.2 and could confirm, that firmware supports TLSv1.2. The question is why TLSv1.1 is used for supl connection? Is there any way to enforce TLSv1.2?
Here is my test script
load_ssl_test.py (1.4 KB)
