We have purchased a 5GM2EVB-KIT units and plan to connect it directly to the radio unit using SMA cables and attenuators instead of antennas, due to licensing limitations.
The radio unit has 4 antenna ports, while the 5GM2EVB-KIT has 6 antenna ports. Is it possible to connect the radio unit to only 4 of the 5GM2EVB-KIT’s antenna ports? Will this configuration work, or could it pose any issues?
Your guidance would be greatly appreciated.
Many thanks,
