Hi!
For testing VoLTE I would like to buy the 5GM2EVB-KIT. Is it supported and configurable in a way, that a custom VoLTE Setup with special APNs is supported? Our Partner Vodafone with it’s 90128 IoT Solution has no own MBN File/config.
Thanks!
Hi!
Thanks!
Dear @avalentin
Which module did you want to test? We need to confirm whether the module support volte.
Hi!
Thanks for the help. I could get the eval board with a RM500Q 5G module. If this does not work, could you please recommend a specific module?
Kind regards,
André
Dear @avalentin
Actually, RM500Q has some varietas, -GL supports volte, -AE is data-only which didn’t support voice.
Hi!
So if I buy the 5FM2EVB with an RM500Q-GL I should be able to test VoLTE usage with the head phone connectors?
Kind regards,
André
Dear @avalentin
If SIM card also support volte, you can test it.
Dear @silvia ,
thanks for you info. I will order the hardwareand keep this thread updated.
I’ve just got my 5G M2 EVB Kit with a RM500Q-GL, and it fails to register:
AT+COPS=?
+COPS: (1,"vodafone.de","Vodafone","26202",7),(1,"Telekom.de","TDG","26201",7),(1,"o2 - de","o2 - de","26203",7),,(0-4),(0-2)
AT+COPS=1,2,"26202",7
+CME ERROR: 30
AT+CMEE=2
+CME ERROR: no network service
If I use the SIM card in a simple 4G LTE stick, it registers immediately with Vodafone. It is a roaming SIM card from Vodafoen global. Is there anything, I should configure before it works?
I tried it at 2 locations, always the same.
